360* Rotating Back Blade Project
/ 360* Rotating Back Blade Project #1
GuglioLS
Edgewood, NM USA
Jinma 354, 1953 Ford NAA Golden Jubilee, Komatsu Bulldozer
I hope you find this an interesting story and project, it has many different paths along the way that lead to an incredible friendship and collaborative effort. If it were not for an interesting turn of events, the results of what you are about to see would not have been possible -
This will take you through concept to completion (sooner or later, probably later):
I got an idea a while back to make the rotational angle of my Back Blade automated. I was constantly getting off & on the tractor to adjust the blade angle for leveling dirt, plowing snow, cutting ditches, etc. I also reverse the blade and back drag the cutting edge for smoothing out high ridges. Anyway I've been thinking about this for quite a while. I've seen a few members that put hydraulic cylinders on them – and they are way cool. I am hoping this project will take their idea to the next level. With this setup I can rotate the blade 360* and everything in between. So I started kicking around some ideas starting with the following concept:
I've had the motor for a couple of years now from eBay. I have another just like it that I made into a TPH winch. The Ring & Pinion gear I salvaged out of an old rear-end I just happen to have laying around. I turned down the splined end of the shaft to 1" OD and cut a 1/4" key slot into it. I used a 1" keyed coupler to attach it to the motor. Man that metal was super hardened, it took a while to turn down and cut the key slot.
After careful consideration, I decided the basic idea of rotating the blade 360* was cool, but the gearing and the construction of the blade itself was not going to work, not at all.
I really want this in a bad way, so nothing is going to stop me.
I thought of all kinds of ways to do this – I even considered rigging up some sort of mechanism that is similar to how a steam locomotive moves a piston back & forth to cause a wheel to rotate 360* – sort of like this:
But obviously that’s a “little” more complicated than I care to fabricate.
There has got to be a better way to do this. I did some more research and thought about a right angle gear box – but never found what I was looking for. Either too big, too small or would not hold the blade against all the forces etc, etc. I finally decided on a worm gear drive mechanism – now I am searching worms & worm gears. Again, I was having difficulty finding anything that was just right for my needs, the gears were just too small and the teeth would be ripped out by the first rock I hit. As a potential solution, I thought about this idea to get as many teeth engaged as possible with a smaller worm gear:
Here is the new design concept (virtual CAD) - a little busy but
I just might be able to fabricate it from mostly off the shelf items.
Nope - again too complicated for me to fabricate, and the chance for failure too great.
Back to the drawing board, as good luck would have it, I stumbled across Martin gears and found these gears. Check out this Worm & Worm Gear that I scored! They are massive, the hardened Worm is 4" long X 3" dia :eek:
The cast Gear is 2" thick X 8" dia it has 24 teeth and weighs 22 pounds.
I picked up a few 4 bolt flange bearings from Surplus Center.
These pic's are of laying out the assortment of parts to get an Idea of how it's all going to be assembled, and to get some rough measurements for steel plate I will need to tie it all together.
Somewhere in there you might notice a few hollow 1-3/8" x 6 spline PTO shaft couplers. Those are what I plan on using in the center of the worm gear that will couple to the back-blade.
In the far right is the hydraulic motor to drive the worm it’s a15 cu in/rev and with the flow from my tractors hydraulic pump it will turn in the neighborhood of 60 RPM.
With 24 teeth on the worm gear, I will get somewhere around 2.5 RPM at the blade.
I have one of the flange bearings setting on top of the worm gear to get an idea of how it will support the gear and PTO driving shaft coupler.
Larry
One thing that has to be done is to machine the inside of the worm gear. The ID is 1.5" and I need to bore it out to 2" dia then machine an internal key slot.
I chucked it to my lathe to see if it fits and turns true. The gear is much BIGGER than I imagined :eek:
Broaching the key slot(s) is something I have never done, so I'm not sure how that's going to work. I have milled key slots in shafts - that seems easy, but cutting a key slot inside ???
Fortunately the worm is already bored & keyed to the size I need :)
Larry
When completed, this is going to be a real convenience. I'm sure it's not cost effective and I will spend more time making it than the accumulative time spent getting on & off the tractor to make adjustments. But what the heck - I think this is a good project to keep me out of trouble.
The gear is huge and I was not exactly sure my lathe could handle it and had questions about cutting out the internal key slot. The gear was expensive and I did not want to mess it up royal.
I went over to seek the advice of my neighbor Herman, he’s a retired machinist. And I had to drop off his Oxy Acetylene tanks that I just got refilled for him. I brought the Worm Gear for him to look at- he was as happy as a clam! His lathe is much larger and was able to hold the Worm gear no problem, so he will bore it out from 1.5" to 2.0" And offered to cut the internal key slot! What a great offer, I have to work (travel all week) and Herman needs something to do. This is a win / win situation for both of us.
Larry
After I got back from my travels I stopped by to see what was happening, This is what Herman got done while I was gone:
He got the Worm gear bored out to 2" ID:
This 1-3/8 x 6 spline PTO shaft coupler is going to be keyed & installed inside the Worm Gear. Two of them will be welded together for the length needed.
Herman is making a tool to cut the internal key slot into the Worm Gear. He is explaining to me how it will work. He’s made these types of tools before to cut internal key slots.
Here's the home made “Red Neck” internal Key cutting “broach” :D
I just got back from helping him cut the key. It takes about 4-6 strokes per .002 depth of cut. It's slow going and man, my arms are about to fall off!
Herman said It's OK to laugh as hard as you want. We both got a real workout raising & lowering the spindle to make the cuts. :rolleyes:
Here is a closer view.
And a shot of the key-way in progress:
Larry
Here's my neighbor Herman :
And a short clip of the actual cutting process:
Larry
Well progress is slow - Sorry this is dragging out so long - I beg your patients please. I seem to be missing the super human machinist "Rob (3RRL) Gene" ;)
Good news is the key-way in the Worm gear is done! It came out nice and I am pleased.
I didn't want to use that 25 year old worn-out back blade for this project. (The one pictured in the very first post on this thread). Not only that, the way it was constructed did not lend itself easily to mount the right angle worm gear box that I am TRYING to make.
So - on my way back from a road trip to El Paso, TX, I stopped by Tumbleweed Equipment and picked up this brand spanking new back blade ;D I checked several styles out and this one is the ticket for what I want to do.
Here's the blade in pieces in the back of my company van.I took it apart so it would fit.
Check out the Ice Berg that fell out of my FEL bucket in the background!
This shows the swinging offset feature. Which will allow the blade to be adjusted to a position off center. I'll install a hydraulic cylinder to control the offset.
The blade and reversible cutting edge. Also shown is the main pivot point. It's 2" dia solid round - just what I was looking for to couple the gear box to.
Larry
That Ice Berg makes a real nice wheel chock ;)
Even though I took it apart, the pieces are heavy :p
Getting it unloaded was all I had time for, plus it's really cold out there.
Larry
Today I got the blade assembled. You might notice the snow has not melted, more is on the way.
Another angle:
Here's a close up of the pivot shaft. I will be making a coupler to slip over it out of 2-1/2 long X 3" dia solid round with a 6 spline PTO adapter shaft bolted to it.
Larry
I am straining my brain on the gear box. The basic concept is sound, But OMG, figuring out all the critical placement and laying it out is what's hurting my brain. I may need to scrap the idea of the 4 bolt flange bearings and go with press fit tapered roller bearings. Also the gearbox needs to be totally enclosed and oil tight. So I am going to take my time working out all those critical details. It is becoming increasingly obvious to me that my skills and little Lathe / Mill combo are just too small for this huge project.
I made a little more progress this afternoon - I have not had much time to devote to working on this. The snow keeps falling and the wind is a blow’n the snow into huge drifts, too busy plowing it :p
I did find time to made the coupler that will connect the back-blade pivot shaft to the center of the worm gear: I actually was able to use my lathe, mill & drill press and did it all by myself ;D
In the foreground is the coupler made out of 3" dia solid round stock 2-3/4" long. I drilled 6 holes 1.25" deep and taped them 3/8-16:
This is the underside of the coupler bored out 2" wide x 1.5 deep
All the holes lined up - whew! and It bolted together nicely.
It's late, dark, snowing (again) and cold - but I had to go out and see if it would fit:
Larry
This is the collection of pieces, parts, & steel I'm accumulating to build the gear box. That’s next :eek: I still got some "engineering" to work out on that though.
And here I am with that "what were you thinking" look.
Larry
At this point in time is when I caught wind that Rob’s (3RRL) tractor was having some sort of electrical issue that prevented the Starter Motor from getting any “Juice”. We discussed it a few times so the next time he was up at his 3 Rivers Camp Property he would try out the suggested fixes. After nearly 6 weeks (three weekends) of no luck. I felt really sorry for him. So I offered to fly out and lend a hand. During our conversations I was really picking his brain about machining. He must have thought (to himself), that I was no machinist, and that my gear box project was heading off the “deep end”. He did not let on, but I know he secretly felt really sorry for me. So here we are, two geniuses, each faced with a problem that neither one could solve. BUT, together, can solve them for each other – I fix Rob’s electrical, and he pick up where my equipment and skills leave off. He offered to help me out - WOW what a guy! Now we are both in business! I am so thrilled that he is going to help me, as I was getting way over my head in what I could actually do.
Rob said to send him all the parts and he would take a look see.
I sent him my “basket case” of gears, bearings and other assorted parts for him to take a look at, and to come up with a plan, This was all prior to my actual visit and fixing his tractor!
Here’s where Rob received all the parts and asses the situation. At this point, I’m sure he has no idea what he’s really gotten himself into.
Notice that bright steel "Halo" above that follows him around?
Larry
At this point, I flew out to California and we met in person for the first time. I saw Rob’s shop – now I understand how he can build ANYTING. The next day he and Loretta took me up to camp, I got his tractor going in 9 minuets and without breaking a sweat – in hind site what a big mistake that was. Wait till you see all the work Rob is doing on my “little” project. Now I feel REAL bad. I should have s-t-r-e-t-c-h-e-d his tractor repair out to the max. Boy, am I dumb.
At one point or another, I sent Rob my Virtual CAD* Drawing:
* CAD (Crummy A** Drawing)
Larry
Now, would you just look at what Rob did to my drawing –
Rob -
“After dropping Larry off at the airport, I managed to get some design work done on his gear box. Larry is a terrific person and a lot smarter than you think. On top of that he is a gentleman and is welcome back for a pleasure visit anytime he wants.
After Larry explained other details what he has in mind for the gear box, things became more clear to me. He is going to use this gear box not only for his blade project, but to run other PTO splined attachments and implements with it...very clever.
So here is what I got done today. I will order steel tomorrow.
This is sheet 1 of 2 on E size paper.
This is sheet 2.
Rob-“
Larry -
What an amazing transformation – Man, this guy is GOOD!
Larry
Rob:
Well,
I guess I better report what's happening with Larry's Gear Box. He gave me a call today to see if I was working on it? I said "Sure, just let me make this last putt and I'll get back to you." :p With that in mind, when I got home I started on his project.
I had bought all the steel for the box yesterday.
Here it is all plied up in my messy garage.
Man, those plates are heavy! I bought lengths and planned on sawing them to size on my Jet saw to save a few bucks on cutting charges.
You can see some chick tried to give me her name and phone number on that one plate....well, not exactly.
Rob-
Rob:
“Buying the plates like that meant I had to start sawing them first.
I started on the smaller pieces first and broke a saw blade right away. Of course that was my last one so off I went to buy some new ones. The local hardware tool supply store only had a 10 tooth in stock but gave me the name of a Saw supply place that carries the 3/4" x 93-1/2" blades in the right tooth set. I was looking for 3 - 4 set but he only had 5 - 8 set in either Starred of Simmonds. I had him make me up 2 blades in that set and it cut super good. Even on the larger 1" x 12" wide plates.
Rob-
I was thinking I better contact Larry so he wouldn't think I stiffed him after all that work he did on my tractor and flying out here. Hahaha, He was probably starting to wonder.
OK, so after sawing and de burring the plates, I decided to "square" them up. This is a small PITA because you have to "indicate" each plate in dead square before making your mill cuts. However, well worth it price wise if you would have seen what they wanted for already ground and squared plates. It was outrageous!
Here I am milling the sides square and to size so I can find center so all the holes that need to be bored into the plates will match up with each other. The bored holes will retain thrust bearings so the locations have to be dead nuts.
I used a Ø3/4" solid carbide 4 flute endmill to do the side milling.
You can see the rusted saw cut disappearing in this picture.
Rob-
I have more steel shots to share today. Taking them and then formatting to upload, etc. is a nice break between the machining. Larry wanted 1" thick steel plates all around except the 2 ends. They are 3/4" thick. Total weight of all the plates (only) is 178 pounds. With his worm and worm gear, collars and bearings etc it's going to be about 240 lbs dry. But there is enough room inside for 10 quarts of oil ... leaving room for the internal components. So it will be pretty heavy duty when it's done and filled. I think I better add an eye bolt for Larry and some handles too? Geez, this is getting better all the time!
I started milling the side plates down from 6" to 5.500".
I put them in my home made milling/ grinding vise that I know is square and parallel all around within .0005" so they would come out good. I made that one in 1978. I have at least 10 like that of different sizes that I've kept, but probably made more like 25 of them over my career.
Here is another shot of the milling to size.
You can see my milling machine head is trammed in perfectly square because the milling cutter marks are equal all around and not tilted.
Rob-
Takeuchi TB235-2 (A62177)
Takeuchi TB235-2...
2025 Pabreak Hydraulic Excavator Arm with Tooth Bucket Skid Steer Attachment (A61567)
2025 Pabreak...
1998 PETERBILT 377 MIDROOF SLEEPER (A58214)
1998 PETERBILT 377...
2019 LARK UNITED CARGO TRAILER (A60736)
2019 LARK UNITED...
SKID STEER ATTACHMENT CEMENT MIXER (A58214)
SKID STEER...
2005 CHANDLER 500 BBL FRAC TANK (A58214)
2005 CHANDLER 500...
