336D injectors
/ 336D injectors #1
Vern
Evening
ordered new injectors from Hoye today, forgot to find out what the torgue spec's for the flange bolts should be. Anyone know?
Vern
/ 336D injectors #2
15 ft pounds. Curious did you order a compression gage also from Hoye?
/ 336D injectors
No I did not, didn't see your post until after I had placed the order. Looking at the injectores I am pretty sure the middle one was plugged, the carbon build up was way above the other 2.
Thanks for your help
Vern
/ 336D injectors
Got curious this afternoon and used a hand held compression gage;
Front and rear cylinder I could not hold in the pressuer was so high.
Middle got up to 75 lbs but I could hold it. Guess I need to dig a little deeper. Will check the valves next.
Vern
/ 336D injectors #5
The gage is clamped like an injector into the head to check compression and is the reason I mentioned it to you earlier.
Btw it should have 450 psi no way a guy can hold that much pressure back by hand plus there is a pre-chamber that has a seal under it further complicating getting a reading with anything other than the right setup.
And valves are set @ .006" cold but as long as they are on the loose side rather than too tight the adjustment will have very little to do with cranking compression, whether they seal or not will most definitely have an effect. hth
/ 336D injectors
Found a bent push rod on the intake of the middle cylinder, straightened it out and every thing looks ok. The clearance was over .020 so tightened it up to .006. Waiting on new injectors due tomorrow.
Vern
/ 336D injectors
Checked the valves, everything is moving as it should. I think the tractor had been sitting for awhile Cylinder has compression, hope that fixes it. New injectors and filters will be here tomorrow.
Vern
/ 336D injectors #9
Hope it runs good once you get the parts in they do run real nice and smooth when everything is right. That's a good machine mine is basically the same tractor it serves me very very well yours should too. :thumbsup:
/ 336D injectors #10
Car doc, can you record your tractor running for us so we can know what a properly running 336 is supposed to sound like?
One issue I have had since day one is not having any idea what a properly running 3 cylinder should sound like. I'd hate to think mine is meant to sound like it does, but have no idea.
2016 American Eagle Reel Trailer (A60352)
2016 American...
2013 FORD F-350 FLATBED (A58214)
2013 FORD F-350...
2012 International WorkStar 7300 AWD Altec DC47TR Insulated Digger Derrick Truck (A60460)
2012 International...
UNKNOWN  SPOOL TRAILER (A58216)
UNKNOWN SPOOL...
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A58214)
2013 ORTEQ ENERGY...
2020 Bobcat MT85 (A53317)
2020 Bobcat MT85...
