336D injectors
/ 336D injectors #112
Good for you. sounds Great. Sure enough it was in the valves.:cool:
/ 336D injectors #113
Great!
Not even going to tell you what I really think this is a family forum ;)
/ 336D injectors #114
Hurray, Hurray, love a good ending. :thumbsup: :thumbsup: :thumbsup:
/ 336D injectors #115
AWESOME! Glad it was something simple. Looks like you are back in action. Good for another 1000 hours without a sweat. Now what projects to use it on?
/ 336D injectors
Thanks everyone
Project to use it on is 24 acres to clear the logging trails to plant food plots.
/ 336D injectors #117
Vern said:
Thanks everyone
I thought you were almost there. Congradulations!
/ 336D injectors #118
thats a sweet sound for sure, Glad its back in action !!
You knew it had to be something simple.....
/ 336D injectors
Had the tractor out to the camp this weekend. it was about 35 degrees and it was hard starting. Loaded on the trailer and road great - 18' duel axle. Almost didn't start to unload but ran great while I cleared and area to park the rv. Sunday morning had a dead battery - would barley turn over and had to run to town to get jumper cables. It was cold so it was a bit hard starting again. I worked it pretty hard for about 3 hours - what ever machine they use to strip the banches off the trees tangles them up pretty good. Best I could do is get the bucket to roll the stuff - have to make a brush fork.
Stopped for lunch and it was still a low battery again but it did start. Got it on the trailer and was not satisfied with the location and tried to start again - dead battery.
Got home and put the charger on - it charged up and tractor started - I am getting 13 1/2 volts to the battery with nothing really drawing other than the starter
Anyone run into this?
Tractor ran great - had some lifter noise so will re check them.
/ 336D injectors #120
Glad to hear she is running good! I dont think 13.2v is enough even if its got a good battery but I suspect the battery is bad since the tractor doesn't draw any power unless the lights are on but thats my guess.
2013 HINO 338 26FT BOX TRUCK (A59905)
2013 HINO 338 26FT...
2012 PROCO 130BBL VAC TRAILER (A58214)
2012 PROCO 130BBL...
CFG Industrial H15R (A60463)
CFG Industrial...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
TOOTHED BUCKET ATTACHMENT FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET...
2024 Linx Trailer (A60462)
2024 Linx Trailer...
