3120 with 72D Autoconnect MMM Problem
/ 3120 with 72D Autoconnect MMM Problem #1
JonBoyHunter
Marion, NY
John Deere 3033R
Just a heads up to anyone that owns an autoconnect deck. I recently was mowing on my 3120 (purchased 06/09, 44 hours on tractor now) when I noticed it was scalping on the right side. Shut her down, got off and noticed the deck was drooping on the right. No problem, I must not have gotten it hooked in properly since I just reinstalled it 10 minutes ago. No such luck - the strap on the deck (1/2" rod bent and welded to the deck) that the rear drag links hook to had snapped off on the right side. I removed the deck, took a closer look, and found a defective weld on the outboard side. There was zero penetration on this side, and the other side snapped off right at the top of the weld. Dealer picked it up the next day, called me 2 days later to inform me that they had ordered me a brand new deck. Supposed to get it back today. Can't say enough about my dealer's service (Ontrac Equipment in Macedon, NY). Might be worth taking a quick look at your decks to make sure the welds are decent - especially if it's still under warranty.
I'll upload some pictures as soon as I pull them off the camera.
Jon Hunter
/ 3120 with 72D Autoconnect MMM Problem #2
I have a 3720 with a 72"d autoconnect... mower deck torques to the right side and scalps. If you are cutting a light stand of grass it works ok. Heavy stands dont work so good. JD DTAC does not seem to have a fix. I am really disappointed with mine.
2001 John Deere 250 Skid Steer (A62613)
2001 John Deere...
New/Unused Wolverine 72in Quick Attach Brush Cutter (A65583)
New/Unused...
2007 Freightliner FLD120 (A62679)
2007 Freightliner...
New/Unused Mini Quick Attach Pallet Forks (A65583)
New/Unused Mini...
CAUTION / STOP SIGNS (A64276)
CAUTION / STOP...
2016 Hyundia 53' Dry Van Trailer (A62613)
2016 Hyundia 53'...
