30hp Chinese Bulldozer Parts
   / 30hp Chinese Bulldozer Parts #61
Not sure about having 2 hydraulic pumps. To the left of the transmission theres a hydraulic cylinder that connects to a lever for forward and reverse operation. 2 lines come off that and go to the hydraulic selector switch. The other 2 lines come from the right side switches which control the 6-way blade and pto lift. I hooked up the lines the way I thought they were and the switch is working to engage forward and it starts to go forward. I put it in reverse the switch moves the lever to reverse but the dozer dont move. I must have 2 lines crossed. The lines off the forward and reverse switch are top bottom left and right. Thanks
   / 30hp Chinese Bulldozer Parts #62
Okay, sorry 'bout that. Had you mistaken for another party.
I know the setup you have now. Check your adjustment (throw) for the reverse portion of the quadrant. It should be equal to the forward throw.
   / 30hp Chinese Bulldozer Parts #64
Ok still no reverse. The throw is the same forward and reverse. I think I have 2 lines crossed. Is there any diagrams out there that shows where the lines go. Thanks
   / 30hp Chinese Bulldozer Parts #65
Sorry, I don't have that information, but if you are getting equal throw in reverse then you may have internal problems.
   / 30hp Chinese Bulldozer Parts #66
Thanks bob. The only thing that I wasnt sure of when bolting the transmission to the gear box was the 3 spacers. I put them between the 2 mating plates. Do you know if thats correct. Maybe they dont go between and its pushing the shaft forward too much. But they are only about 3/8" thick. Thanks
   / 30hp Chinese Bulldozer Parts #67
Apologize for the late reply. Not sure what "spacers" and "mating plates" you are referring to. A picture would help if possible.
   / 30hp Chinese Bulldozer Parts #69
I need a new starter QD1247A for a rino dozer
How do you know you need a new starter?
What engine do you have? Sounds like a weird number to me.
Try Circle G Tractor and Affordable Tractor.
   / 30hp Chinese Bulldozer Parts #70
I have a two cylinder 30 hp diesel. I checked the armature with an ohm meter and one burned copper plate shorts to all the others. The number on the starter is QD1247A. It is a 1.5 kw 12v starter.
UNUSED RAYTREE RTSG30-30" STUMP GRINDER (A51248)
UNUSED RAYTREE...
2007 FREIGHTLINER BUSINESS CLASS M2 DUMP TRUCK (A51406)
2007 FREIGHTLINER...
NEW Wolverine 72'' Skid Steer Sickle Bar Mower (A53002)
NEW Wolverine 72''...
UNUSED FUTURE FT2P 12 VOLT PUMP (A51248)
UNUSED FUTURE FT2P...
1994 Prevost Liberty Coach 40FT Class A Motorhome (A51694)
1994 Prevost...
PAIR DIAMOND PLATE DBL AXLE FENDERS (A51247)
PAIR DIAMOND PLATE...
