3054 4x4 lever not working
/ 3054 4x4 lever not working #1
wanasrx
Bronze Member
NY
Kioti 3054
My son was using our 3054 and was trying to put it back in 2 wheel drive and something has gone wrong. The lever just flops up and down. I think something bad has happened inside. Any advice is greatly appreciated. It currently operates fine in 4x4 but has always been under tension when switching from 4 to 2 wheel. I believe the tractor in a 1993.
/ 3054 4x4 lever not working #2
Check the linkage underneath, you may have only lost a pin or something.
/ 3054 4x4 lever not working #3
Same thing happened with my lb1914. A small pin had fallen out of the linkage. Hopefully that is all it is
Hope your right, I'll take a closer look. Thank you
Pin is there, something is broken inside. Wont be able to get to it for a while. Hope it's ok to run it as is in 4x4. No strange noises anyway.
/ 3054 4x4 lever not working #6
As long as you don't try to use it on a paved surface you should be OK (assuming whatever's broken doesn't jam in a gear or something). I rarely put mine in 2WD.
