3010 reassembly help
/ 3010 reassembly help
I still cant get it to go in all the way. When i took it back apart it looked like the shaft was hitting low. I used the alignment tool when i put the clutch pack an disc back on. I had it pretty straight and square today especially with the guide bolts. Not sure whats going on.
/ 3010 reassembly help #12
If that's the case, rotating the engine might get it to go If the clutch disk was high, 1/2 a turn might lower it enough to engage the shaft.
I've been turning the flywheel if that's what you mean.
/ 3010 reassembly help #14
Yes, that's what I meant.
My 2030 only has one clutch disk (PTO clutch is internal) and I have just eyeballed to center. It (on my 2030) is the inner shaft that engages it, and it has some play at the end.
I finally got it together after wrestling with it for hours. I guess it just needed to be lined up exactly right. Thank you for your suggestions and help. I greatly appreciate it.
/ 3010 reassembly help #16
It's good feeling when a split tractor comes back together! Especially when it takes a long time.
Oh yeah awesome feeling. Works great. I cried a little when it went together.
2014 Chevrolet Silverado 4x4 Crew Cab Pickup Truck (A56858)
2014 Chevrolet...
2016 WANCO WTSP PORTABLE ARROW BOARD (A60429)
2016 WANCO WTSP...
2007 Ford Crown Victoria Sedan (A59231)
2007 Ford Crown...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A57024)
NEW HOLLAND 706 30...
2014 Freightliner M2 106 Palfinger PK22002EH 6 Ton Knuckleboom Flatbed Truck (A55973)
2014 Freightliner...
MACK T/A DUMP TRUCK (A58375)
MACK T/A DUMP...
