3010 reassembly help
/ 3010 reassembly help
I still cant get it to go in all the way. When i took it back apart it looked like the shaft was hitting low. I used the alignment tool when i put the clutch pack an disc back on. I had it pretty straight and square today especially with the guide bolts. Not sure whats going on.
/ 3010 reassembly help #12
If that's the case, rotating the engine might get it to go If the clutch disk was high, 1/2 a turn might lower it enough to engage the shaft.
I've been turning the flywheel if that's what you mean.
/ 3010 reassembly help #14
Yes, that's what I meant.
My 2030 only has one clutch disk (PTO clutch is internal) and I have just eyeballed to center. It (on my 2030) is the inner shaft that engages it, and it has some play at the end.
I finally got it together after wrestling with it for hours. I guess it just needed to be lined up exactly right. Thank you for your suggestions and help. I greatly appreciate it.
/ 3010 reassembly help #16
It's good feeling when a split tractor comes back together! Especially when it takes a long time.
Oh yeah awesome feeling. Works great. I cried a little when it went together.
Kubota RTV X900 (A53317)
Kubota RTV X900...
14in Digging Tooth Bucket Excavator Attachment (A60352)
14in Digging Tooth...
2023 CAN-AM DEFENDER RTV (A59823)
2023 CAN-AM...
Ford F450 Bucket Truck with Altec AT200A Boom (A56435)
Ford F450 Bucket...
2025 ZJG ZJ-380 Mini Stand-On Track Loader Skid Steer (A59228)
2025 ZJG ZJ-380...
2015 Chevrolet Impala Sedan (A59231)
2015 Chevrolet...
