3010 reassembly help
/ 3010 reassembly help
I still cant get it to go in all the way. When i took it back apart it looked like the shaft was hitting low. I used the alignment tool when i put the clutch pack an disc back on. I had it pretty straight and square today especially with the guide bolts. Not sure whats going on.
/ 3010 reassembly help #12
If that's the case, rotating the engine might get it to go If the clutch disk was high, 1/2 a turn might lower it enough to engage the shaft.
I've been turning the flywheel if that's what you mean.
/ 3010 reassembly help #14
Yes, that's what I meant.
My 2030 only has one clutch disk (PTO clutch is internal) and I have just eyeballed to center. It (on my 2030) is the inner shaft that engages it, and it has some play at the end.
I finally got it together after wrestling with it for hours. I guess it just needed to be lined up exactly right. Thank you for your suggestions and help. I greatly appreciate it.
/ 3010 reassembly help #16
It's good feeling when a split tractor comes back together! Especially when it takes a long time.
Oh yeah awesome feeling. Works great. I cried a little when it went together.
2014 International WorkStar 7400 Service Truck with Crane, VIN # 1HTWGAAR1EH765285 (A61165)
2014 International...
2019 KUBOTA KX033-4 EXCAVATOR (A60429)
2019 KUBOTA...
2018 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A60352)
2018 Chevrolet...
2012 International WorkStar 7400 Service Truck with Crane, VIN # 1HTWGAAR1CJ453408 (A61165)
2012 International...
2008 CAT D6T DOZER (A58214)
2008 CAT D6T DOZER...
John Deere 1025R (A53317)
John Deere 1025R...
