3010 Basket Case
/ 3010 Basket Case #11
What JD tractor would you choose for a rebuilding project to end up with a usable keeper?
rScotty
I'm not fond of the JD rowcrop 10 series pto speed change gears/tiny shift pins so my vote would be for 20 series such as 3020/4020
/ 3010 Basket Case #13
My aging eyesight only saw you state diesel & gasoline powered 3000 series engines but you didn't mention LPG AKA propane powered
Oh, I see. Yes, it could be interpreted that way. Aging is something I'm all too aware of.
For myself I kind of like propane. It's clean and tidy and old propane engines always seem cleaner with less wear on metals and on seals - especially so compared with modern gasoline.
But a propane engine is not something I'd recommend for a person with limited experience working on an unknown system indoors - i.e. winter in Alberta. Not that gasoline is all that great, but at least it is familiar.
But what about diesel? I'd say that for myself, if I was to get into an old tractor with diesel I'd do so without much worry if the tractor already had a good-running diesel in it. I probably wouldn't tackle a large older tractor with a broken diesel engine. I'd rather do a transmission....
rScotty
/ 3010 Basket Case #14
The thing about the 4020 is it is just more tractor than most people have a use for. But they sure were/are popular. I've heard there are still repair shops that work on 4020s almost exclusively. A classic...but a big one.
They weigh as much as our Kubota. :)
rScotty
/ 3010 Basket Case #15
rScotty
On subject of fuel choices after diesel I'd prefer LPG over gasoline. JD 4 & 6 cylinder rowcrop engines such as 3010/3020 posess don't perform well utilizing gasoline with ethanol in it . JD trans such as the Syncro-range is not a trans that I'd suggest for a novice technician to attempt to repair. Many special tools are required. I still remember how frustrating it was installing the four(4) springs & balls inside the synchronizer hub even when utilizing the """special cone""". Also dummy shafts are needed for installing bottom shaft in SR trans.
/ 3010 Basket Case #17
Well, you have to have a gasoline engine to run either or both. Diesel engine wont do.
/ 3010 Basket Case #18
I disagree that gasoline & propane powered engines are the same. Normally propane engines have higher compression & hardened cylinder head valve seats vs gasoline engines. I agree propane can be utilized in an engine designed for gasoline but propane won't provide the same power as gasoline in a normal gasoline powered engine. FYI some engines that were powered by gasoline can also be powered by diesel. Many yrs ago for kicks & giggles I operated my JD BO on diesel that the engine was designed to operate on distalites or gasoline. Propane has been utilized in addition to diesel in a diesel engine to increase horsepower.
/ 3010 Basket Case #19
Lets just say spark plug engines and non spark plug engines.
/ 3010 Basket Case #20
Some older IHC diesel engines had both spark plugs & injectors. Spark plugs on one side of cylinder head & injectors on opposite side. They starting operating on gasoline & switched over to operating on diesel
2013 PETERBILT 389 SLEEPER (INOPERABLE) (A60736)
2013 PETERBILT 389...
2022 CAN-AM BOMBARDIER LIMITED RTV (A59823)
2022 CAN-AM...
Giyi PG72 QA 72" Grapple (A60463)
Giyi PG72 QA 72"...
2021 Bobcat E42 R2 Series (A60462)
2021 Bobcat E42 R2...
2005 Chevrolet Impala Sedan (A56859)
2005 Chevrolet...
2017 Nissan Rogue SUV (A59231)
2017 Nissan Rogue...
