Case 310G Dozer - Rebuild/Repair Project and Questions
/ Case 310G Dozer - Rebuild/Repair Project and Questions #21
Dont worry bout not seeing the marks on the flywheel----there are none on them!! I have the 188 in my old 580 ck and the pump is junk on it too. I have the valves up just like you and no marks on the flywheel. I am going to just yank the pump off at this point and go from there.
I had a little time today and decided to dig into the engine a little bit more.
I removed the oil pan - no surprises there. There was nothing in pieces or any sign of metal in the oil that was left in there (maybe a cup full).
I removed the rocker arms, shaft and brackets, then I started removing the nuts that hold the head on. I thought I had them all, but I discovered that there was also a bolt with a hole through it that is behind the water pump (had to remove the water pump to get to it.
After that, I made my first discovery of what might be wrong - both of the push rods for cylinder number 4 were bent. Almost exactly the same amount. All of the other push rods were straight.
Then I got the head off and had a look at the cylinders. Cylinder number 4 (with the bent push rods) had diesel fuel and/or a little oil in it, whereas all of the other cylinders were bone dry. I'm assuming that this was my dead cylinder and what may have been causing the knock.
As far as next steps from here, I guess I will work on removing the pistons and then remove the rest of the covers and gears from the engine so I can get to the crankshaft and see if there's any damage there.
Unfortunately, I'm probably going to be taking a break from this project for a while because I have to start working on cleaning out fencelines which is, for me, primarily a winter time activity. Whenever it's too rainy, I'll get back to this project and try to keep moving it along.
Thanks.
/ Case 310G Dozer - Rebuild/Repair Project and Questions #23
sounds like you found the problem! keep us up to date when you get back on it!
Well - good news and bad news. It was a bit rainy, so I had more time to work on the engine.
I rolled the engine over to start removing the pistons and there it was - the connecting rod for the No. 4 cylinder was broken, and the bearings were gone (and nowhere to be found inside the engine so far. There was, of course, some damage to the crankshaft, so the next order of business, at least as far as that's concerned, will be to finish getting the crank out so I can take it to a machine shop to see if it can be ground down or not. I know that as I've looked a rebuild kits, a lot of them have options for oversized crankshaft bearings.
The bottom of the No. 4 piston was damaged as well, but I didn't see any other damage to the inside the block. All of the other cylinders came out pretty easily, but that one was stuck a little bit more.
I carried on and removed the oil pick up and oil pump (there was only one shim between the oil pump on the bearing block). I also got the crankshaft nut and crankshaft pulley off. I noticed on the pulley (before I pulled it off) that it has been pulled at some time in the past, because there were two bent spots on the rear rim of the pulley. I used a puller and it came off relatively easily. The shaft surface for the front seal looks to be in good shape.
The valves on the No. 4 cylinder were also pretty sticky - especially the exhaust valve. I don't know if the valve stuck, then the piston hit it and broke the connecting rod or if there was a different chain of events. Who knows..
At any rate, I've at least discovered why the engine was knocking. Now all I've got to do it finish fixing everything and replace all the broken parts and put it back together.
Piece of cake, right?
This will probably become a lengthy process (because I'm going to have to roll some pennies to pay for all of this), but I would rather take the time and spend the money to get it right this time and end up with a solid dozer rather than rush through it and mess something up worse.
I appreciate any thoughts and advice anyone has. Anything in particular to be aware of regarding having a crankshaft ground or having a valve job done on a cylinder head?
Thanks.
/ Case 310G Dozer - Rebuild/Repair Project and Questions #25
Diesel engine hardly ever gets bored, its reselved to original size or bored and inserts reinstalled. So far as head, crank and rods, they are all done like a auto shop would do.
If block is intact your half way there
/ Case 310G Dozer - Rebuild/Repair Project and Questions #26
I told you in my first post, they are rod throwers!!!
Time to retire that POS and buy a used 207 to put in it's place!
NEXT time it pitches the rod, it just may go through the block!!!
SR
/ Case 310G Dozer - Rebuild/Repair Project and Questions #27
I never had any problems with the 188's case used, BUT the one IH used in 2504's ate rod bearings kinda bad.
I tried to contacted a machine shop that works on ag/industrial equipment (as well as cars) and the machinist said that he could evaluate the crank for $25, so once I get it out, I'm taking it and the head to him go get them checked out.
In the meantime, I received the Case service manual that I ordered to help me out with this. It's about 1,000 pages and it looks like it covers most everything. I think it will end up being worth the money. First order of business with it will be to scan it so I can print as many copies of a particular section (so I can get them dirty and greasy without worry). I've messed up too many manuals in the past thinking that I could keep them clean while wrenching on things.
Thanks.
Well, it's been a while since I got anything productive done on this project, but I do have a bit of an update (I spent most of the winter chainsawing and cleaning out fence lines while it was cold and wet).
I finally finished stripping the block, getting the crankshaft and camshaft out. I think that I'm going to end up taking the crank, cam, head and block all to the machines shop so he can check them all out and replace the sleeves as well (he will replace them cheaper than I can buy the puller).
I'm planning on sending the pump and injectors out for rebuild shortly. In the meantime, I'm going to turn my attention to the rest of the tractor and work on fixing some other things that are a bit worn and damaged, and giving it a thorough cleaning and possible re-paint job.
Any tips on proper paint prep? All I've ever done in the past is wire wheel/sanding and then prime and pain. Usually with decent results, but I'm by no means a painter.
I'll try to post a few more updates as I go along.
Thanks again for the all the advice.
Oh, and as a complete aside - if anyone needs a .PDF copy of a 310 manual, I scanned all of mine in sections so I can re-print as I need so I don't get grease all over the originals. If you need something, let me know and I can send it to you.
Thanks.
/ Case 310G Dozer - Rebuild/Repair Project and Questions #31
Sounds like you have a solid plan. Wish I could help on the paint job, all my experience is with houses. I do believe you get what you pay for in paint, and that it's always smart to ask for advice from the people that sell paint for a living on what works best for what you are wanting to do. I would go to an automotive paint store, not a home paint store, and see what they recomend.
Well, I've got all the parts at various shops and starting to get some results in.
Bad news on the radiator - the top tank is pretty much shot, and the core is not much better. The shop said that they could patch it but would't guarantee that it would hold for long once it got to being used.
The only replacements I've found look like they run into the $1,500 range. However, there are a ton of radiators that were used in different machines that used the 188 engine. I'm going to see if any of those might fit as I had a pretty good amount of room under the hood with the old radiator.
Anybody have any experience with universal radiators with electric fans? I was thinking of maybe going that way, but I have no idea how to go about sizing a radiator. I would love to hear any advice on that subject.
Thanks again.
/ Case 310G Dozer - Rebuild/Repair Project and Questions #33
Thanks again.
If you plan on actually working the machine, FORGET about an electric fan.
Just my :2cents:
/ Case 310G Dozer - Rebuild/Repair Project and Questions #34
When I needed a new fan for my Case 1550 dozer, the parts guy said that they didn't carry it any longer. But he did spend a lot of time looking for something off of a different machine with the same engine to see if he could find something that would work. After a few weeks, he gave up. There was a wheel loader that was kind of close, but not close enough.
Eventually I found a dismantler that had what I needed. I was nervous paying them so much money for it, but it arrived strapped to a wooden pallet in excellent condition.
I've contacted the local Case industrial place and he is seeing what he can find. He said he thought that some other radiators would fit it if I could do some fabrication for the mounts and re-mount the shroud, but he wasn't sure which. I'm going to go pick my old radiator up and and mount it and the cowl back on the frame and take some measurements and see what I can find that might fit.
Thanks for the help.
/ Case 310G Dozer - Rebuild/Repair Project and Questions #36
I have found that CAT paint is excellent, and it is not at all expensive.
I believe that it is made for CAT, by Sherwin Williams.
I've made some progress since my last update -
1. Injection pump and injectors are back from rebuild and should be ready to be installed
2. The crankshaft was too damaged to be repaired, so I picked up a new replacemnt
3. Rebuild kit has arrived and I'm going to be taking it to the machinist shortly. He is going to pull the old sleeves and make sure that portion of the block is okay and then install the new sleeves for me. He is also doing the valve job on the head.
4. Some other miscellaneous parts have arrived.
Hopefully should be getting everything back together in the next month or too.
Good luck and take care.
2005 Wacker Neuson PDT3A Portable Diaphragm Pump (A59228)
2005 Wacker Neuson...
2014 Ford Explorer SUV (A59231)
2014 Ford Explorer...
Crown RM6025-45 Stand-On Electric Forklift (A59228)
Crown RM6025-45...
2020 CATERPILLAR 336 EXCAVATOR (A60429)
2020 CATERPILLAR...
2024 CATERPILLAR 305CR EXCAVATOR (A60429)
2024 CATERPILLAR...
2018 Toro Z-Master 6000 Series 74in Zero Turn Commercial Mower (A59228)
2018 Toro Z-Master...
