3 Point Log Skidder
/ 3 Point Log Skidder
Why are you guys using chains instead of cable chokers?
For my part; I use both. When I have a steady length requirement, I go with cables, when I need different attachment lengths, I go with chain. Taking into consideration that I'm graduating from an ATV and arch (with 0-10" of lift) to a tractor with a 3 point with much-more height capability.
/ 3 Point Log Skidder #43
Not a 3 point log skidder, but I thought I would show another way to do it, with the stump bucket.
After I drag the big ones out of the woods, I grapple them to the burn pile.
The V417 is 6' wide, 6.5' high and 13' long. Tire size is 14x17.5. Top speed is 15.5 mph, drawbar pull is 7,000 pounds and it will lift over 5,000 pounds. With 4 wheel steer it works good in the woods.
/ 3 Point Log Skidder #45
PhysAssist, I noticed you wear leather gloves and was complaining about using cable as the barbs go right through them. Weat heavy cotton gloves, they are much better about stopping the strands from getting to you. Here in the Northwest we use a brand called White Ox. Pretty much standard wear for loggers.
/ 3 Point Log Skidder #46
You could try welding the frayed ends of the wire together.
/ 3 Point Log Skidder #47
That is awesome! I can't see a winch; is that a winch too?
Thank you!
No it doesn't have a winch. It does have counter weights on the back side of the plate.
/ 3 Point Log Skidder #48
Thanks for the advice, as I would never have thought that cotton would out perform leather in puncture resistqnce.
300 Gallon Portable Fuel Tank (A64127)
300 Gallon...
Magnolia Trailer with Adams 25 Ton Fertilizer Tender (A63688)
Magnolia Trailer...
Unverferth Assist Wheels (A64127)
Unverferth Assist...
Front Tank Bracket (A64127)
Front Tank Bracket...
2013 VOLVO A25F 6X6 OFF ROAD DUMP TRUCK (A62129)
2013 VOLVO A25F...
(2) Firestone 18.4-16.1 Tires w/Rims (A64127)
(2) Firestone...
