3 Point Log Skidder
/ 3 Point Log Skidder
Why are you guys using chains instead of cable chokers?
For my part; I use both. When I have a steady length requirement, I go with cables, when I need different attachment lengths, I go with chain. Taking into consideration that I'm graduating from an ATV and arch (with 0-10" of lift) to a tractor with a 3 point with much-more height capability.
/ 3 Point Log Skidder #43
Not a 3 point log skidder, but I thought I would show another way to do it, with the stump bucket.
After I drag the big ones out of the woods, I grapple them to the burn pile.
The V417 is 6' wide, 6.5' high and 13' long. Tire size is 14x17.5. Top speed is 15.5 mph, drawbar pull is 7,000 pounds and it will lift over 5,000 pounds. With 4 wheel steer it works good in the woods.
/ 3 Point Log Skidder #45
PhysAssist, I noticed you wear leather gloves and was complaining about using cable as the barbs go right through them. Weat heavy cotton gloves, they are much better about stopping the strands from getting to you. Here in the Northwest we use a brand called White Ox. Pretty much standard wear for loggers.
/ 3 Point Log Skidder #46
You could try welding the frayed ends of the wire together.
/ 3 Point Log Skidder #47
That is awesome! I can't see a winch; is that a winch too?
Thank you!
No it doesn't have a winch. It does have counter weights on the back side of the plate.
/ 3 Point Log Skidder #48
Thanks for the advice, as I would never have thought that cotton would out perform leather in puncture resistqnce.
2021 Sany SMG 200C-8 Motor Grader (A62679)
2021 Sany SMG...
2020 GMC AT4 CREW CAB TRUCK (A62130)
2020 GMC AT4 CREW...
Bish Wide Body Claas Face Plate Kit (A63117)
Bish Wide Body...
2002 Chevrolet C7500 MTI 805B-47 47ft Bucket Truck (A64194)
2002 Chevrolet...
2025 Swict 84in. Bucket Skid Steer Attachment (A61572)
2025 Swict 84in...
2022 John Deere 6R 130 Tractor (A63111)
2022 John Deere 6R...
