2615 Clutch Question
/ 2615 Clutch Question #1
specialkkl
PA
2006 mahindra 2615 hst
When I push my clutch in it hits this piece of metal ( has small lockdown bracket for clutch on it) (shown in pic). If I just push the pedal a little left it will go past it. My question is, is the clutch fully disingaged at this point or should the pedal be traveling past this point. Thanks. Having some trouble with the pic but I will try to get it on here as soon as I can. In the meantime if anybody knows what I'm talking about it would be appreciated.
/ 2615 Clutch Question #2
That metal piece with the "clutch hold-down clip" has a bolt with a screw adjustment on it.
The clutch pedal should NOT go past that point as it could do damage to the clutch. That bolt limits the travel of the pedal. If the pedal goes past it, there is a problem.
If you look in your manual under clutch adjustment, it should have a measurement for minimum freeplay, and maximum pedal travel.
/ 2615 Clutch Question #3
Also, your clutch is fully disengaged at the point where you could use the clip to lock the clutch pedal down. (probably sooner than that, but definitely by that point)
Thanks Driver
2014 CATERPILLAR 573C FELLER BUNCHER (A64276)
2014 CATERPILLAR...
Skid Steer Blank Plate (A65640)
Skid Steer Blank...
2008 SUBARU LEGACY 4 DOOR SEDAN (A64280)
2008 SUBARU LEGACY...
Cattle Feeder (A65640)
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2015 Chevrolet...
Winchester Metal Sign (A65583)
Winchester Metal...
