Odd. What is the failure mode of black poly?
Here in TX the majority of black poly for sale is rated for 80 psig. Very thin-walled. For some reason the stores don't stock the thicker 200 psig stuff.
My parents put in 400 ft of black poly back in '81 when they built their house in the NC mountains, 3 ft down, no issues yet. While in Afghanistan in 2011, I had the water line replaced at my place in central Tenn, the guy used 20' sticks of sch 40 pvc. I had to dig it up three times a year later to repair breaks and bad joints. After the third time, I put in 400' of black poly, no issues up to when I sold the place last year. 20' sticks of pvc just doesn't make sense, too many joints to create leaks.
In terms of 50yrs pressure, water, and ground burial, what is the alternative? ... Stainless Steel?
Good input. I too am looking at using poly (HDPE); assuming, of course, I can find it in 1" diameter (OD for the jokers above), 300' long and 200 psi pressure rated. I'll be enclosing it in 3" ridged drain line for protection against the limitless number of rocks around here.
Where did you find you 400' of poly?
Thanks,
From what I've been reading about tracer wire is that it has to have a PVC coating, even though I'll be burying my water line and tracer wire inside 3" corrugated drain line. Regular THHN insulated wire won't work - for very long anyway.
Thanks,
Just to clarify......do you want 1" ID pipe? or 1" OD pipe (which would be a 3/4" line)
Where in TN are you? I dont know how far south menards has expanded, but they can get alot of that black pipe, and best prices I found when shopping for geothermal piping. Just have to decide on what side you want.
1" SIDR 7 pipe is 250 psi rated, and 1.349" OD , 1.049" OD..............$212......400'
1" SIDR 9 pipe is 200 psi rated, and 1.283" OD , 1.049" ID............$153.........400'
1" CTS in SDR 9 is 250 PSI rated, 1.125" OD, 0.875" ID.................$153........400'
3/4" SIDR 7....250PSI ......1.060" OD.....0.824" ID....................$97-300'.....$178-500'
3/4" SIDR 9....200PSI.......1.008" OD.....0.824" ID....................$73.......400'
3/4" CTS....SDR 9...250PSI....0.875" OD.....0.681 ID................$93.......400'
And whatever you get, I think you are going to have a hard time trying to shove it through 3" drain pipe. Which I think is not needed anyway.
I went with 2" pvc for about 750' and put it down about 24". I was more concerned about gophers and getting nothing but steam on the other end if buried shallow. Not to mention it crosses a pasture that could get worked in the future. Our frost line is about 1/2" down here but the summer sun will practically boil water. Gophers will eat through 1" or less PVC so put the pipe down below their 12" range of burrowing.
