250' water line: got some questions
   / 250' water line: got some questions #41
Whatever pipe you choose, just make sure the OD is larger than the ID. Otherwise, the hole will be on the outside of the pipe.:cool2:
Sorry, couldn't resist. Old engineering joke.
   / 250' water line: got some questions #43
:cool2::dance1::thumbsup::):D:laughing:
   / 250' water line: got some questions #45
my 2 cents -- if you going to bury locator wire, why use insulated wire ? I would go with bare copper and run the wire to the inside of the house and use it for ground bonding when needed. a few extra feet is not going to hurt your budget plus you can give it a dual purpose.
   / 250' water line: got some questions #46
The cost of 18 gauge stranded wire is about the cheapest wire you can get. Is there bare copper wire that's cheaper?
   / 250' water line: got some questions #47
My parents put in 400 ft of black poly back in '81 when they built their house in the NC mountains, 3 ft down, no issues yet. While in Afghanistan in 2011, I had the water line replaced at my place in central Tenn, the guy used 20' sticks of sch 40 pvc. I had to dig it up three times a year later to repair breaks and bad joints. After the third time, I put in 400' of black poly, no issues up to when I sold the place last year. 20' sticks of pvc just doesn't make sense, too many joints to create leaks.
The tracer device I have (linked previously) works by sending a signal down the tracer wire with the other device wire connected to a separate ground. Having both grounded wouldn't work.
Good input. I too am looking at using poly (HDPE); assuming, of course, I can find it in 1" diameter (ID for the jokers above), 300' long and 200 psi pressure rated. I'll be enclosing it in 3" ridged drain line for protection against the limitless number of rocks around here.
Where did you find you 400' of poly?
Thanks,
From what I've been reading about tracer wire is that it has to have a HDPE or HMWHDPE coating, even though I'll be burying my water line and tracer wire inside 3" corrugated drain line. Regular THHN insulated wire won't work - for very long anyway.
Thanks,
CATERPILLAR 299D3 SKID STEER (A60429)
CATERPILLAR 299D3...
PowerBoss Admiral Plus 38C Ride-On Floor Scrubber/Sweeper (A59228)
PowerBoss Admiral...
2019 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A59905)
2019 INTERNATIONAL...
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
HUSQVARNA RIDING MOWER 46IN DECK (A56859)
HUSQVARNA RIDING...
2005 Detroit Diesel 100DSEJB 138kVA 3-Phase Diesel Generator (A59228)
2005 Detroit...
