450' water line
/ 450' water line #1
frank29
Bronze Member
Atlanta, Georgia
I need to replace a problematic water line. Existing diameter (1-1/2") provides plenty of volume & pressure. Problem is the constant leaks, at least a dozen over the past 20 years. The existing blue colored line is a "bell & socket" design: each length is 20', one end has an enlarged end which has a rubber O-ring, the other end just slid into the enlarged end. It has the same diameter as PVC, in fact the end coming through my basement wall is reduced using standard PVC fittings.
Some of the leaks have an understandable cause such as trees roots growing next to a joint. Other leaks are mystery leaks worthy of the X-Files. The convuluted path the line took contributed to this. Now that my property is developed, the new line will follow the driveway and hopefully avoid some of my past problems.
The last time I had a leak I promised myself, as I sat in a muddy trench, that the next leak would prompt a compete replacement. That time is now.
I am undecided between 20' lengths of PVC and longer lengths of coiled poly pipe. Any strong opinions on this?
As far as poly pipe is concerned, there seem to be a lot of options (at least compared to PVC). Any thoughts on particular brands or connection methods? Using a barbed insert into either end of a pipe and tightening with clamps seems to be inferior to PVC solvent welded connections?
Thanks for any help.
/ 450' water line #2
I think it would be instructive to do an analysis of the CAUSE of each of the prior failures. The point is, poly pipe is flexible and a tree root will push against it, deform it, but not likely BREAK or shatter it such as can happen with PVC.
On the other hand, poly is perhaps more susceptible to a puncture from a rock or very sharp object.
Look into pulling with a subsoiler whichever type of pipe you end up using. I've pulled poly black coil and it works well... there are reports on TBN that others have pulled links of PVC after they are joined together and dried.
So, I'd try to do a $ cost analysis, installation time analysis, installation equipment cost, likely reliability analysis given your conditions of soil and leak history..... and, hopefully, an answer will emerge.
/ 450' water line #3
Ive pulled in several thousand feet of poly pipe using my subsoiler. Through clay, loam, rocks and more. So far its never leaked, and it sure is quick to install.
PVC would have taken days and days to install, but at least its more expensive :)
Cran
/ 450' water line #4
frank29 said:
I The existing blue colored line is a "bell & socket" design: each length is 20', one end has an enlarged end which has a rubber O-ring, the other end just slid into the enlarged end.
This is the good stuff and probably something most people have never seen. it's very expensive and about as good as it gets for water lines. Like anything else, if it's not installed properly, it will fail. I'm at a loss to why it's leaking, so please be more specific. My guess is it wasn't installed properly. You don't bend it, you don't put glue joints on it and you must be sure to block it at the ends of a run. It will move. It's designed to move. The important thing is to limit it's movement so it works as it's designed.
Your first choice for a new line should be the blue, slip jointed pipe. It's either C-900 or C-909. It's not easy to install, but it's not rocket science either.
Next would be Schedule 40 PVC. The problem with PVC isn't the wall thickness. Schedule 80 is stronger, but it's so much overkill that there's no advantage to it in underground applications. Schedule 80 is mostly used for above ground use. The weekness in PVC is the glue. It doesn't actuall glue the pieces together, but sort of welds them together chemically with primer and then glue. This gives you a very solid seal, but there's no flex in it. If you have clay soils, or soil that moves, then PVC will be stretched to the breaking point. My experience isn't all that great, but I've see these breaks and it's either the middle of the pipe, or the joint pulls apart. When it's the joint, you can see part of the plastic pipe actually breaks away.
Black Poly comes in several thickness's and lengths. The thicker is better and your only real option. I forget the ratings as it's not something I'd ever use. Lots of guys have it on there homes, especially for lines running from a well to the house. It seems to last for them, so it's OK in some areas.
My main issue with it is the City of Tyler used it in part of the city for their water lines. I don't know how much of it is in the ground, but it's not working out. They have crews that work 24/7 fixing leaks. It's so common, that's all those guys do. I know this first hand as I had one of those homes that had a line break. It took them a few hours to get there as they were working on another leak. We chated while they fixed it and really drove the point home to me at how bad it is. The city would replace it, but with all that they have in the ground, it's cheaper to keep the crews out working on patching it.
Before you start on this, you really should go talk to somebody at your water district and find out what works, and what doesn't. They live for this stuff and go to meetings all the time on it. Plumbers might be helpful, but nowhere nearly as knowledgable as your water district.
Soil, distance, depth, preasure and money need to be figured into what to use and how to install it.
Good luck,
Eddie
/ 450' water line #5
I would put the pipe regardless of type in a bed of pea gravel or squeegee. it allows for subtle movements in the pipe and if you need to dig up a portion to repair it, it sure beats getting compacted clay soil off the pipe. Put a 3" to 6" bed of gravel down first, then lay in the pipe, then put at least another 6" of gravel in before you cover it up with 6" to 12" of native earth. I also like to put detectable marking tape above the pipe before it gets covered up by native earth.
I know this adds to the cost; but it's easier to do it now while the trench is open than later.
/ 450' water line #6
EddieWalker and mjncad posted replies while I was typing mine, and I mostly agree with both of their posts. Considering EddieWalker's post describing problems with polyethylene (PE), and my post below, it seems that PVC may be the way to go. And mjncad's suggestion of backfilling with pea gravel is an excellent idea, but could be pretty expensive for your 450' line. If your trench is 12" wide and you cover the pipe with 6" of pea gravel, you'll need more than 8 cubic yards of pea gravel (about 11 tons). Check your local source to see if that's affordable. Also consider whether you have the means to distribute the gravel. Of course if your trench is only 6" wide, you'd need only half that amount.
Around here, a 250' roll of 125psi 1-1/2" PE pipe runs around $180 as of August, 2007. That's about 72 cents per foot.
A 20' long stick of schedule 40 PVC glue-type bell end runs about $7 which is about 35 cents/foot. I don't have a price on PVC with the o-ring type bells.
Check your local suppliers for prices in your area!
You have a 450' run. Assuming the prices I gave above are correct, the difference in price for the pipe alone would be $166 in favor of PVC. I think that difference would be about the same or perhaps even greater if you factor in the cost for fittings for the PE and the cost of primer and glue (if any) for the PVC. So it comes down to how much your time is worth. Gluing or driving together 22 joints in the PVC....that's about $7.57 per joint for your labor. If you can do a joint in 15 minutes, that's like paying yourself $30/hour. And that's assuming that man-handling the 250' rolls of PE takes no time at all.
I doubt if you have a subsoiler that can lay 1-1/2" PE line, but if you did, that would probably be the way to go as marimus suggested.
/ 450' water line #7
Here's my experience:
I put in a 600' water line using 1-1/2" polyethylene (PE) black plastic pipe with only one joint. For that joint I used a brass barbed coupling and triple clamped it (six stainless steel clamps). Then I "marked" the joint by burying four or five flattened aluminum cans just a few inches underground above the joint. I also put in a T-post to temporarily mark the spot (twelve years ago, and the post is still there). By the way, when you clamp PE, it's wise to go back the next day and tighten the clamps again. They also make a coupler that has a stainless steel sleeve that fits up inside the pipe, with a heavy split brass clamp that goes around the outside of the pipe and is tightened with a couple of bolts. That's a much more secure coupling, but they aren't cheap. I'd have used one, but I didn't know about them at the time I laid the line.
Then I put in an additional 120' of 1-1/2" line using 20' sticks of PVC pipe with a bell on one end. I glued that pipe using primer and then the glue. I backfilled the first few inches of that by hand, also.
My water pressure is 70psi which is quite high, but I've had no leaks on either part of the line. I put the line 36" deep and backfilled the first few inches by hand to avoid large rocks up against the pipe.
If I had to do it again, I would probably go with PVC.
I used PVC for the 120' stretch because I didn't want to buy a 250' roll of PE for a 120' stretch. The PE may be quicker, but costs more and the pipe is softer. The PVC is cheaper but the pipe is brittle, and if you glue the joints, it's somewhat time consuming. The o-ring joints are pretty quick (if you lubricate the o-rings with soap), and they allow for some movement of the pipe. I've used them for drain pipes, but I'm still not convinced that the o-ring joints are as good as glued joints for pressurized water lines.
/ 450' water line #8
Wow, I can't believe how cheap PVC is for you guys!
Over here, pvc is several times the price of PE pipe (of any pressure rating).
We use PE for town water supplies, but there is never any leak issues with it. They butt join the pipes using a special tool that heats the pipes and then clamps the ends together.
The PE I uses is of "rural" designation, which is rated to 120psi and is marked with a green stripe. Higher pressure pipes have a blue, or yellow stripe for the highest rated.
Cran
/ 450' water line
EddieWalker said:
.......if it's not installed properly, it will fail. I'm at a loss to why it's leaking, so please be more specific. My guess is it wasn't installed properly......
I'm sure that was a big part of my problem, at least early on. Shortly after the intial install the first slip joint (20' from the meter) started leaking. I cut out a section and solvent welded a piece of PVC in. A week or two later the secon slip joint (40' from meter) started leaking. Same fix, except this time I noticed the meter had been pushed back by the pressure causing the first two joints to leak....luckly the next joint (60' from meter) had enough friction through 60' of ground contact to stop pushing the meter.
Other understandably leaks were caused by tree roots.....the line's original (current) path was dictated by my ability to navigate a trencher through my undeveloped densly wooded lot. Bad move. A good part of the line runs through areas that are still densly wooded, hense, tree roots problems. The replacement line will run alongside the driveway and greatly reduce this problem.
The rest of my problems are just plain wierd. For example, last summer I had two tees start to leak. These tees had never been used. In case I every wanted to add another spigot, I put a tee in line with a short capped stub. In both places I put a meter box & cover. I don't know if they started leaking at the same time or not, all I know is I was searching for a leak and found both problems at the same time. The leaks were at the foot of the tee....I probably not describing this correctly: where the tee crosses forming a perpendicular crossing, the PVC was cracked! When I saw this I called a plumber, he saw no reason for such a thing, the line is straight and not in a bind.
My neighbors have no problems. I know I caused some of the early on problems, maybe I caused all the problems; I just know I want a new line running through a cleared area and the idea of minimizing joints sounds appealing.
Thanks to all for the input.
/ 450' water line #10
PVC, PVC, PVC
I agree with Eddie Walker, that jointed pipe doesn't leak unless it's installed incorrectly.
PVC freezes and shatters, and PE won't
BUT
PVC has wayyyyyy better flow characteristics and will not get eaten by tree roots, where poly will (it gets squeezed, impossible to find until it finally breaks, can take years)
Prime every joint, gray glue, twist as you put it together. The bell faces the water source. (you'll see it, it's not a hard step facing the water if you do it that way)
PVC lasts 50+ years, poly lasts about 20.
Just bury the PVC 1' below your frost line., won't be a problem.
/ 450' water line #11
It's been my experence when you have trees anywhere . The roots of those trees cause problems . We have seen roots grow around the poly pipe & pvc ( it usually breaks the pvc) & squeeze the pipe off so that no water will flow through the pipe
/ 450' water line #12
When I put water on my place in Feb 2002 I used the 20' sections of 1 1/2" PVC glued ends, I put in 350' and have had one break (dec 05) and it was my fault, I had too much pressure on a 90deg bend...it was my first time to install water pipe, before the break I always wondered how long that would last...almost 3yrs... Having a BH at your disposal and spare parts is very handy for fixing these things quickly.
/ 450' water line #13
TedLaRue said:
... Also consider whether you have the means to distribute the gravel. ...
From personal experience, pea gravel distributes quite easily with a hand held landscape rake. Even my less than athletic body was able to do it. As far as putting the gravel in the trench, a light touch with the loader bucket will allow you to drizzle the gravel in over the pipe.
As for pipe type, my preference is PVC. Of course you could really go whole hog and use Type "K" copper coils; but then you are talking real money!
/ 450' water line #14
I've never heard of using pea gravel, so maybe it's a technique used up north??? My first experiece with water lines was putting them in for the city of Santa Cruz in California. They are pretty close to a major earthquake fault and have more regs and codes then just about anybody for building.
All the pipes were slip jointed and set in a bed of sand. One foot of sand all around the pipe. No rock, no dirt, just clean sand. This was inspected by the city and something that they took very seriously.
Here in my area of Texas, we don't have much rock. If it's encountered when digging a trench, you just don't use it when you fill your trenches. Regular clean dirt (red clay) is used to fill the trenches.
The reason the waterline faile the first two times is that it wasn't blocked. When you install slip joint pipe, you have to block the end of the pipe. For my waterline, I used a dozen 80 pound sacks of readimix with rebar through the sacks. If you don't have something at the end of the pipe, it will pull apart over time. This sounds just like what happened for the first two leaks.
Something else to consider is to put a preasure regulator on your water lines. Most city water lines will have surge. There's allot of reasons for this, but the preasure is never constant. It will spike from time to time, and depending on where you life and your utility, the spikes can easily go into the low 100's of pounds. Just because the pipe is rated for 200 or 400 pounds, doesn't mean it can last over time with the flexing of high and low preasure.
Black pipe is very prone to fail and this is one of the reasons.
Eddie
/ 450' water line #15
Originally posted by LoneCowboy
... PVC freezes and shatters, and PE won't. ...
I agree that PE won't shatter, but I know that it can split if the water in it freezes. I think it's probably more tolerant to a little freezing than PVC, but I've repaired an above ground PE line (a coil used as a crude solar water heater) several times because it split when residual water in it froze. I wised up and now I blow it out with an air compressor before winter.
... PVC has wayyyyyy better flow characteristics and will not get eaten by tree roots, where poly will (it gets squeezed, impossible to find until it finally breaks, can take years) ...
I'm not sure I agree with this argument. I don't see how PVC could have better flow characteristics when it has joints every 20 feet. In frank29's 450' run, the PE would have only one of those stainless steel insert type couplers, which causes almost no restriction or turbulence at all. But the PVC would have 22 joints in it. Granted, those joints are pretty smooth too, if the installer followed your advice of having the bell face the source. But that can't be any better than a single joint in the PE. Now if for some reason the PE has a lot of joints in it, and if those joints were made with the barbed couplers with hose clamps, I agree 100% with you that the PVC has better flow characteristics.
Also, don't you think that roots that could squeeze PE could also crush PVC? That 1-1/2" PE has really thick walls. If squeezed by roots, it might give a little, but the PVC would just crack.
Maybe your experience has been with that thin wall 60psi PE stuff which is meant for very low pressure irrigation and such. In that case I'd agree with what you're saying. But the PE rated for municipal water distribution is much heavier and stands up pretty well to PVC.
/ 450' water line #16
The pebbles in pea gravel are smooth without sharp edges. Near here we use either sand or pea gravel depending on which is available for the least price.
It's nice stuff to backfill with if you have a loader to distribute it the whole length of your trench (450 feet for the original poster frank29). It's still a lot of tractor shuffling around to dump the stuff 5 feet at a time (if your loader is 5' wide). And you really need to have a helper on the ground watching to tell you when you've dumped the right amount for that 5' length of trench.
/ 450' water line #17
EddieWalker suggested installing a pressure regulator. I think that's a good idea. Pressure regulators are usually installed inside the house, so that may or may not be an option for the original poster frank29.
You might also want to consider installing a check valve at the end of your line closest to the water source. It doesn't cost much for a 1-1/2" check valve. The reason for installing one is that if the supplier (water company) has a leak below the elevation of your property, the check valve will prevent your lines from being siphoned dry. Of course if your property is near or below the level of the public line feeding you, this wouldn't help.
/ 450' water line #18
TedLaRue said:
I
Look it up in your plumbers book
quite a bit better
There's a reason you don't use poly for long runs.
You'd think so, but it doesn't happen.
I've never seen it and I've dug up a LOT of pipe.
/ 450' water line #19
Several considerations concerning the line "following" the driveway frank29. Be sure you consider upgrades and drainage, if not you could have problems. The phone company decided the best way to lay my line was up the middle of my drive and then, oops, off the the side in a place or two. Needless to say, I've have to be really careful or decide between grading the road and having a phone line.
Terry
/ 450' water line #20
Any chance you could run a 1" line thru the existing line. It would give you extra protection from roots.
