2210 Quick Attach Options?
/ 2210 Quick Attach Options? #1
millers1
Eastern - West Virginia
Deere 2210, X320
I have a few impements for my 2210... cat 1 scraper, post hole digger, ballast box, etc... I was hoping to go with the i-match type of quick connect system but the implements have different widths between the pins. That pretty much rules out the i-match, right? What other quick connect options would I have for my CUT?
/ 2210 Quick Attach Options? #2
All depends on the design of the hook points of the scraper. Some are quick hitch compatable and some are not. The post hole diggers you cannot use quick hitches.. I have the Harbor Freight and everything I have will work with it. Its the 27.5" wide one. If you can, post a picture of the scraper or might be able to tell if you post what brand it is.
/ 2210 Quick Attach Options? #3
You can get the iMatch type and modify all your implements to fit it-if you have that capability, you could also look at the Pats Easy Change
The Pat's easy change may be my best option. My ballast box is i-match compatable but the Landpride 60" scraper blade is only 26" (outside of pin to outide of pin) width. I guess I could get creative with the scraper's pins but may be more work than it's worth. BTW.. just used the scraper for the first time today.. can't believe I didn't get one sooner.
/ 2210 Quick Attach Options? #5
Your scraper just needs the bushings, measure your ballast box as i think its also 26in
Edit: is it the very out side of the pin or where it bolts on
2022 CATERPILLAR 299D3 XE SKID STEER (A65053)
2022 CATERPILLAR...
Year: 2018 Make: Towmaster Model: TC-16 Vehicle Type: Trailer Mileage: Plate: Body Type: Trim Lev... (A61567)
Year: 2018 Make...
NEW ATS-SP100 100 Ton Capacity Shop Press  (A62679)
NEW ATS-SP100 100...
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
International Day Cab (A62613)
International Day...
2012 Palomino Ultra-Lite Camper Trailer (A66285)
2012 Palomino...
