2210 Quick Attach Options?
/ 2210 Quick Attach Options? #1
millers1
Member
Eastern - West Virginia
Deere 2210, X320
I have a few impements for my 2210... cat 1 scraper, post hole digger, ballast box, etc... I was hoping to go with the i-match type of quick connect system but the implements have different widths between the pins. That pretty much rules out the i-match, right? What other quick connect options would I have for my CUT?
/ 2210 Quick Attach Options? #2
All depends on the design of the hook points of the scraper. Some are quick hitch compatable and some are not. The post hole diggers you cannot use quick hitches.. I have the Harbor Freight and everything I have will work with it. Its the 27.5" wide one. If you can, post a picture of the scraper or might be able to tell if you post what brand it is.
/ 2210 Quick Attach Options? #3
You can get the iMatch type and modify all your implements to fit it-if you have that capability, you could also look at the Pats Easy Change
The Pat's easy change may be my best option. My ballast box is i-match compatable but the Landpride 60" scraper blade is only 26" (outside of pin to outide of pin) width. I guess I could get creative with the scraper's pins but may be more work than it's worth. BTW.. just used the scraper for the first time today.. can't believe I didn't get one sooner.
/ 2210 Quick Attach Options? #5
Your scraper just needs the bushings, measure your ballast box as i think its also 26in
Edit: is it the very out side of the pin or where it bolts on
2007 Dodge Ram 2500 Service Truck with Crane, VIN # 3D7KR26D67G784488 (A61165)
2007 Dodge Ram...
UNKNOWN TANK MANIFOLD (A58216)
UNKNOWN TANK...
JLG Scissor Lift (A64047)
JLG Scissor Lift...
UNUSED RAYTREE RMVR76 - 76" VIBRATORY ROLLER (A62131)
UNUSED RAYTREE...
2004 Chevrolet Tahoe 4x4 (MPV), VIN # 1GNEK13Z24R318274 (A61165)
2004 Chevrolet...
2004 International 4300 S/A Day Cab Truck Tractor (A61568)
2004 International...
