2166 alternative drive fluid
/ 2166 alternative drive fluid #1
edjones72
South Georgia
Yanmar YM2210, Cub Cadet 2166, JD2940, Mustang 440 skidsteer
What is everyone's thoughts on using something other than Cub Cadet brand drive fluid in a 2166 transmission. The Cub Cadet brand is extremely expensive compared to other oils. Any thoughts or experiences would be greatly appreciated.
Eric
/ 2166 alternative drive fluid #2
hi edjones72
There is alot of threads on this.Just look at some old theads i hope that helps.IMO i would get the cub oil.It may cost more but why take a chance,it's not like you have to change it often.
good luck
/ 2166 alternative drive fluid #3
Lots of debates on this. Shell Rotella-T 15w-40 works flawlessly in the transaxle on my 2005 model year 2544. Mine specs Cub Cadet Drive System Fluid Plus. FWIW, I would not hesitate to use ANY high quality heavy-duty engine oil, preferably synthetic/semi-synth, in the 40-50wt range.
Joel
/ 2166 alternative drive fluid #4
(oops, posted my reply in the wrong thread)
/ 2166 alternative drive fluid #5
Joel
Joe where did you get the specs for the CC drive fluid. I, and my dealer, would like to know. He said MTD wouldn't tell him.
/ 2166 alternative drive fluid #6
Moe, I called Hydro-Gear directly and spoke with one of their engineers about the oil. He faxed me the data sheet. The oil is made by Shell and is called Shell TTF-SB. Per specs, it's not a very impressive oil. Just a run of the mill synth blend heavy-duty engine oil. I've got the data sheet posted here on other threads. So you don't have to poke through a pile of threads, here it is:
Joel
/ 2166 alternative drive fluid #8
Kub I have searched the internet and can't come up with a source for that fluid. Have you purchased any and if so where did you get it??
Thanks
