2166 alternative drive fluid
   / 2166 alternative drive fluid #1
edjones72
South Georgia
Yanmar YM2210, Cub Cadet 2166, JD2940, Mustang 440 skidsteer
What is everyone's thoughts on using something other than Cub Cadet brand drive fluid in a 2166 transmission. The Cub Cadet brand is extremely expensive compared to other oils. Any thoughts or experiences would be greatly appreciated.
Eric
   / 2166 alternative drive fluid #2
hi edjones72
There is alot of threads on this.Just look at some old theads i hope that helps.IMO i would get the cub oil.It may cost more but why take a chance,it's not like you have to change it often.
good luck
   / 2166 alternative drive fluid #3
Lots of debates on this. Shell Rotella-T 15w-40 works flawlessly in the transaxle on my 2005 model year 2544. Mine specs Cub Cadet Drive System Fluid Plus. FWIW, I would not hesitate to use ANY high quality heavy-duty engine oil, preferably synthetic/semi-synth, in the 40-50wt range.
Joel
   / 2166 alternative drive fluid #4
(oops, posted my reply in the wrong thread)
   / 2166 alternative drive fluid #5
Joel
Joe where did you get the specs for the CC drive fluid. I, and my dealer, would like to know. He said MTD wouldn't tell him.
   / 2166 alternative drive fluid #6
Moe, I called Hydro-Gear directly and spoke with one of their engineers about the oil. He faxed me the data sheet. The oil is made by Shell and is called Shell TTF-SB. Per specs, it's not a very impressive oil. Just a run of the mill synth blend heavy-duty engine oil. I've got the data sheet posted here on other threads. So you don't have to poke through a pile of threads, here it is:
Joel
   / 2166 alternative drive fluid #7
Thanks Kub...
   / 2166 alternative drive fluid #8
Kub I have searched the internet and can't come up with a source for that fluid. Have you purchased any and if so where did you get it??
Thanks
2020 DRAGON ESP...
2016 Ford F-550 Palfinger PSC3216 4,000LB 2 Ton Crane Service Truck (A55852)
2016 Ford F-550...
2022 CATERPILLAR 302.7 CR EXCAVATOR (A52707)
2022 CATERPILLAR...
UNUSED FUTURE P680 67" HYD BREAKER HAMMER (A57193)
UNUSED FUTURE P680...
2016 CATERPILLAR CB34B SMOOTH DBL DRUM ROLLER (A52707)
2016 CATERPILLAR...
2008 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2008 INTERNATIONAL...
