2020
Eddie
Platinum Member
North Alabama
YM2020 & Allis Chalmers 6060
Need information on 2020. Good, Bad, parts available? How does the shift work on it? I think it's a 3 cylinder motor. Any information would be helpful. Thanks!!!
Good tractor. Parts not as prevailant as the 00 series, simply because they are a newer model. Give them time, some day the YMXX00 models will run out and you will see more later models. The shifter of the YM2020 as well as all the 20 series is located below the steering column. You can shifter from neutral to reverse or any forward gear with or without clutching. And yes it is a 3 cylinder engine.
1994 SHOP MADE ENCLOSED TOOL TRAILER (A58216)
1994 SHOP MADE...
3PT FENCE ROW SPRAYER (A63291)
3PT FENCE ROW...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
UNUSED INDUSTRIAS AMERICA HYD POST PULLER (A60430)
UNUSED INDUSTRIAS...
2020 Ford F-150 4x4 Crew Cab Pickup Truck (A61573)
2020 Ford F-150...
2017 Ford F-150 Pickup Truck (A61573)
2017 Ford F-150...
