1st project - waterfall
/ 1st project - waterfall #2
All im going to say is it looks GREAT.
/ 1st project - waterfall #3
emery
Looks good/w3tcompact/icons/smile.gif
<A target="_blank" HREF=http://www.tractorbynet.com/forumfiles/6-96272-falls.jpg>http://www.tractorbynet.com/forumfiles/6-96272-falls.jpg</A>
I might do a water project in the spring, looking into ideas now.
regards
Mutt
/ 1st project - waterfall #4
Emery, Nice Job. I like to see what other folks are doing as it helps me formulate my plans. I have dreams of building a Water Mill at the top of our spring fed creek and cascading down into a pond. Purely aesthetic project however. Someday, maybe...
Todd in Placerville
/ 1st project - waterfall #5
Just saw your post regarding the waterfall. Couple of questions. What type of pump and size do you use? Is there more than one pump bringing the water back up? The granite you show came from a used site? Or did you buy from vendor which I assume was very expensive.
I am working on a 5 year arbortium plan for my yard which will include a waterfall and I like your example.
Paul
Paul, the granite is recycled curbing stones that I got for free from local road project. Around here they do not reuse curbing as it takes to long to clean old stones so they always replace with new. I used ordinary silicon chauking to seal the joints.
The pump is a $50 1/3 horse submersible that has run fine now for 3 years. It pumps just about the right amount up about 10' height. I use ordinary garden hose and split the flow with a Y valve to 2 streams up on top.
/ 1st project - waterfall #7
Thanks for the reply, when you used the word granite the first thing that comes to mind is very hard stone and expensive.
Paul
2018 VOLVO SD75B SMOOTH DRUM ROLLER (A65053)
2018 VOLVO SD75B...
3147 (A63117)
3147 (A63117)
Can Am Defender (A63688)
Can Am Defender...
(2) 10 LUG WHEELS (A64281)
(2) 10 LUG WHEELS...
STIHL HT103 POLE SAW (A62613)
STIHL HT103 POLE...
UNUSED WOLVERINE 60" HYD DRUM MULCHER (A64281)
UNUSED WOLVERINE...
