Oil & Fuel 1972 Ford 2000 3 cyl Diesel Engine
/ 1972 Ford 2000 3 cyl Diesel Engine #1
djdavidc1
Ardmore, OK
Ford 2000
I changed the engine oil on my Ford 2000 3 cyl diesel tractor and put the specified 8 quarts of oil in the engine. The dip stick showes it to be over filled after sitting idle for a day. Do I have the capacity correct?
/ 1972 Ford 2000 3 cyl Diesel Engine #2
How much overfilled? In those days the dipstick was marked with an "Add" line which was later changed to a "Safe" range. Casting variations caused the standard factory fill to occasionally fall below the old "Add Oil" line resulting in a lot of warranty claims for low oil (but none for too much). It has to be significantly overfilled to be a concern. If it's just a bit its probably just fine.
/ 1972 Ford 2000 3 cyl Diesel Engine #3
Did you start it and let it run for a minute or two?
MASSEY FERGUSON 2605 TRACTOR (A60430)
MASSEY FERGUSON...
57" HYD LOG LOADER GRAPPLE (A60429)
57" HYD LOG LOADER...
2022 JOHN DEERE 700L LGP CRAWLER DOZER (A60429)
2022 JOHN DEERE...
2021 JOHN DEERE 6145R TRACTOR (A59823)
2021 JOHN DEERE...
UNKNOWN  500BBL WHEELED FRAC TANK (A58214)
UNKNOWN 500BBL...
UNUSED FUTURE EXCAVATOR THUMB (A60432)
UNUSED FUTURE...
