Oil & Fuel 1972 Ford 2000 3 cyl Diesel Engine
   / 1972 Ford 2000 3 cyl Diesel Engine #1
djdavidc1
Ardmore, OK
Ford 2000
I changed the engine oil on my Ford 2000 3 cyl diesel tractor and put the specified 8 quarts of oil in the engine. The dip stick showes it to be over filled after sitting idle for a day. Do I have the capacity correct?
   / 1972 Ford 2000 3 cyl Diesel Engine #2
How much overfilled? In those days the dipstick was marked with an "Add" line which was later changed to a "Safe" range. Casting variations caused the standard factory fill to occasionally fall below the old "Add Oil" line resulting in a lot of warranty claims for low oil (but none for too much). It has to be significantly overfilled to be a concern. If it's just a bit its probably just fine.
   / 1972 Ford 2000 3 cyl Diesel Engine #3
Did you start it and let it run for a minute or two?
ITEM LOCATION (A53084)
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2016 Hino 258 Roll Back (A52384)
2016 Hino 258 Roll...
2008 CATERPILLAR 304C CR EXCAVATOR (A51406)
2008 CATERPILLAR...
2013 HINO CONV. ICE CREAM TRUCK (A52472)
2013 HINO CONV...
