1967 sears ss12
/ 1967 sears ss12 #1
scott5
WEST BROOKFIELD
1967 seaes ss12
Hello looking to see if anyone knows where I can get a head or motor for my 67 ss 12 machine is real clean original condition , replaced head gasket still leaking out of front of motor I was told to double up gaskets not sure if that would be
wise .
/ 1967 sears ss12 #2
If it is the surface of the head being out of plane, you could take it to a machine shop and have them deck the head, which should make it easier to seal.
David from jax
/ 1967 sears ss12 #3
I think those are an iron block Tecumseh? At least that is what the SS12 had that I grew up on. A straight edge could prove helpful.
/ 1967 sears ss12 #4
You're right tomplum. They were iron blocks with aluminum heads. As long they're torqued probably they are usually pretty forgiving. 2 head gaskets isn't the answer. I'd have the head checked to make sure its not warped. Easy thing for a engine machine shop.
/ 1967 sears ss12 #5
I'm thinking that may be a Tecumseh HH120. Model number should be stamped in the top of the shroud. If it is, the part number for the cyl. head is 33034. Did a search, and seem to be plentiful, but pricey. Saw a few anywhere from $82+change, to $86+ change. Head gasket was under $5.
Just do look for the number on the shroud to find the correct model, then do a search for that models parts. More than several exploded view diagrams, with part numbers to look it up. Always use the part number when looking.
/ 1967 sears ss12
Thanks for that info the numbers I pulled a serial #7174 model 143-572012 head a 31961 or a 31058 I called a couple of places said they were obsolete I did see 33034 looks similar will have to take mine apart
again to measure holes
Caterpillar 3208 Power Unit (A64127)
Caterpillar 3208...
2018 Deere 672GP (A64126)
2018 Deere 672GP...
3Pt Rhino Forklift (A66408)
3Pt Rhino Forklift...
2008 Genie AWP-30 Single Manlift (A61572)
2008 Genie AWP-30...
Volvo Water Truck, 3306 Cat Engine (A62679)
Volvo Water Truck...
31" Minin Excavator Bucket (A66285)
31" Minin...
