1533 question
/ 1533 question #1
Bungiex88
Dysart
73 Farmall 574, 2016 mahindra 1533
Was looking at getting a set of forks for the front of my tractor and had a question. It says it will accept skid steer style quick disconnect forks. I saw some forks for sale but is there a backing plate I would have to buy to. I wasn't sure if a skid steer already had a backing mounting plate.
CJJ Skid Steer Attachments Replacement Fork 71849 by Cj Inc. for $234.97 in Skid Steer Forks & Frames - Skid Steer Attachments - 3 Point Equipment & Accessories - Agriculture : Rural King
These are the ones I was looking at
/ 1533 question #2
It looks like those are replacement forks so come short the skid steer mount so you'd have to add that. If it were me I'd just get a set of skid steer forks from Titan, Bradco etc. else that comes complete and ready to replace the bucket without needing anything else. Choose a weight rating consistent with your loaders lift capacity and be done with it.
/ 1533 question #3
Yep those r replacement forks and not the whole item you need. Forks are very common so a local dealer or Craigslist/eBay will have them. Several online folks have them as well. Avoid the ones that have a lot of solid metal around the top of the back. It makes it hard to see what you are doing from the drivers seat. I'm sure the rental yard has some if you are in a pinch.
/ 1533 question #4
Note the message towards the bottom.
This replacement fork for the pallet frame attachment.
**Sold in increments of 2!!!
/ 1533 question
OK I wasn't sure since my tractor had a quick disconnect wasn't sure thank for letting me know
/ 1533 question #6
That is just the replacement forks for this complete unit:
CJJ Skid Steer Attachments Heavy Duty Pallet Fork with Frame 9111 by Cj Inc. for $1,229.97 in Skid Steer Forks & Frames - Skid Steer Attachments - 3 Point Equipment & Accessories - Agriculture : Rural King
Something like this would be more in line with your machine:
Blue Diamond Attachments Pallet Forks 2lb Capacity Skid Steer 3143 by Blue Diamond Attachments, Llc. for $678.97 in Skid Steer Forks & Frames - Skid Steer Attachments - 3 Point Equipment & Accessories - Agriculture : Rural King
I personally wouldn't pay more than $550 (shipped or local) for a CUT pallet fork, unless it was something special that could be used on 3 point as well as SSQA or had other attachments such as bale spears, etc.
/ 1533 question #7
I'm almost certain you have a skid steer mount loader and bucket. If you see the disconnect levers on the bottom rear of the bucket then you know for sure. It's made by KMW (Kansas Machine Works) BTW. KMW supplies the loaders and backhoes for the 1500 series machines. You should see a KMW sticker on your loader. The sales data for your machine also says you have a skid steer type mount.
/ 1533 question #8
You definitely want to be sure you can see what your doing, cause aluminum gates don't do well when being stabbed by forks. ;)
2015 Peterbilt 337 Galbreath CH8000 Container Handler Truck (A64194)
2015 Peterbilt 337...
JOHN DEERE 5075M TRACTOR (A63291)
JOHN DEERE 5075M...
2004 BMW 325ci Convertible Coupe (A62613)
2004 BMW 325ci...
2023 SANY SY225C EXCAVATOR (A63276)
2023 SANY SY225C...
1042 (A60430)
1042 (A60430)
1975 Bomag MPH1 Reclaimer Mixer / Soil Stabilizer (A61572)
1975 Bomag MPH1...
