110 arc welder
/ 110 arc welder #1
tessiers
Platinum Member
Central Maine
05' JD 790 - 53' Ford NAA - 70' Massey Fergusen 135 diesel - 67' John Deere 3020 deisel - 77' John Deere 2130 - 1950 John Deere MC
anyone got one of those little 110 arc welders, 50 to 70 amp. I have a large Stick welder and a wire feed mig welder in my shop but I have a chance to pick up a small 110 arc welder for pocket change so to speak. wondering if it will ever get used, or turn into another piece of junk laying around?
/ 110 arc welder #2
unless you need the portability of the 110v it sounds like a waste of time, money, and garage space to me
/ 110 arc welder #3
I use my Lincoln 110V mig on the lower settings for thin metal all the time so I would say that if it is cheap enough and you think you might have a need for it you may be surprised how handy it will become. I never thought I would use mine as much as I do but it will weld things you can't begin to with my stick welder. With practice, you can weld very thin metal or even thicker metal than you would initially guess.
Opps. on edit: I see you said 110 stick, I thought you made reference to one of the small 110 migs. whole different creature I would imagine and I have no experience with them. Sorry for the confusion.
/ 110 arc welder #4
Most 110v Stick Welders are toys. They make better DC Tig units than Stick units. One to look at is the Thermal Arc 95S. It will easily weld 1/4" with 6013,7014, 7024 or other similar rods. priced at about $300. Other 110v Stick units, Buyer beware.
/ 110 arc welder #6
I've heard a bit about 110V stick welders and all of it is bad. My only actual experience with a 110V stick machine was a Miller Maxstar that was a joy to use....it can't be had for pocket change, I'm afraid.
/ 110 arc welder #7
with a unit like this, you need to consider the intended usage and use a little common sense about this. if you're uttering the name of a welding machine manufacturer that sells units costing as much as a small car, you're comparing apples and oranges. these units should not even be considered if yo are thinking of using it to fabricate anything, or something that you intend to do often.
however, a unit like this is going to be a godsend if you have anything made of metal that may need to be repaired, where perfect appearance and 100% strength are not required. if you have a hobby farm, or anything even remotely resembling a tractor, then something like this will probably be very handy.
if you break something that requires more than duct tape for a temporary fix, and have to call a portable welder in, or haul the broken item to a shop, you've probably lost several hours of time, and what you pay to have a repair would have paid for one of these little units. myself, i prefer a 120v wire feeder with flux core, but thats a bit higher of a price range. if i was on a budget, one of those little 120v sticks would be the ticket.
many people swear by their 240v mig with the big gas bottle and roll around cart and 240v stick, but when something breaks outside on a windy day, that mig with gas flux isn't worth much more than scrap weight. also, when a friend with no mechanical capabilities calls and has something broken at his house down the road, those 120v units can get up and go in a hurry. odds are he doesn't even have anywhere to plug in the 240v unit.
/ 110 arc welder #8
if you have a small mig.. or one that will work suitably on thin sheet metal.. then you don't need the small stick.
I have a 235a stick, and a 30/70a stick.. i use the small one for sheet metal work.. ( no mig at my house yet.. )
soundguy
/ 110 arc welder #9
The Maxstars work really well. They're able to put out a lot of current because they convert the AC to DC using a diode bridge to add both halves of the AC together to make DC. They will also connect to 120 or 240 automatically. I've done an entire pipe fence with my Maxstar. But, as noted they are not inexpensive.
/ 110 arc welder #10
I used the Maxstar primarily for stick or stainless TIG. For my last welding job as an employee, I did a job putting railings in stairwells. We'd drop a Trailblazer 302 outside the door and run cables up. What we ended up doing is running a fat extension cord up as well and running a Maxstar off the auxiliary power.
We could both run 3/32" 7018 without being able to "feel" when the other guy was welding; 1/8" was pushing our luck; especially for the fellow running the Maxstar. Since we weren't putting down very large welds, running tiny electrodes wasn't an issue. We had a dual operator set on the cheap!
/ 110 arc welder #11
You can't beat a small 110 volt stick for quick light repairs even on up to a 100 ft 12 ga extension cord. but as in my other posts 6013 Lincoln rods 3/32.
INGERSOLL RAND BLAW-KNOX PAVER (A67714)
INGERSOLL RAND...
2023 CHEVROLET W5500 4X2 S/A 16FT FLOOR TRUCK (A67148)
2023 CHEVROLET...
(INOP) 2006 INTERNATIONAL 7400 DUMP TRUCK (A65054)
(INOP) 2006...
2026 DEVELON DX27Z-7-US30 EXCAVATOR (A64279)
2026 DEVELON...
x (A68191)
x (A68191)
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A66736)
2016 Ford F-150...
