1020 hydraulics
/ 1020 hydraulics #1
stonestacker
auburn ca
1020 diesel 4wd-1936 RD4 CATTERPILLER-1948 FARMALL CUB
got a1020 it had sit for a while, fired it up and no hydraulics! so added some fluid and still nothing loader or rear.
is it possible there is air in the lines or pump:confused: Thanks for your support Bill
/ 1020 hydraulics #2
from sitting a relief valve maybe stuck open try it 2-3 times a day it mite shut and your good to go ..some of the older tractors had a ball on a spring and it would stick open and shut down the hydraulics .. good luck
/ 1020 hydraulics
Thanks for the input,where would the relief valve be on the 1020?
/ 1020 hydraulics #4
that i dont know ...every tractor has them in different spots .good luck
/ 1020 hydraulics #6
Check to see if the pump is pumping fluid.
The pump may need primed.
Have you checked and replaced the hyd filters and cleaned the screen if it has one.
New/Unused Wolverine 78in Quick Attach Smooth Bucket (A65583)
New/Unused...
4021 (A59228)
4021 (A59228)
White 5100 12R Planter (A66285)
White 5100 12R...
1985 Ford F-250 Pickup Truck (A62613)
1985 Ford F-250...
2020 VOLVO EC200EL EXCAVATOR (A65053)
2020 VOLVO EC200EL...
1980 Fontaine Flatbed Trailer (A65563)
1980 Fontaine...
