Menu
Forums
Today's Posts
New posts
Search
Marketplace
Auctions
Database
Quick Review
Quick Owner-Page
Register
Log in
Join
What's new
Search
Search
Everywhere
Threads
This forum
Search titles only
Today's Posts
New posts
Search
Filters
Keywords:
Started by:
Last updated:
Any time
7 days
14 days
30 days
2 months
3 months
6 months
1 year
Hidden from guests
Sort by:
Sort order
Last message
First message
Title
Replies
Views
First message reaction score
Sort direction
Descending
Ascending
Menu
Log in
Join
Main
General Tractor Topics
You should upgrade or use an
alternative browser
Hydraulics
Discuss all issues relating to hydraulics in this forum.
Prev
1
Go to page
Go
62
63
64
65
66
Go to page
Go
273
Next
First
Prev
64 of 273
Go to page
Go
Next
Last
Filters
Show only:
Loading…
Filters
D
First time diy fluid change
dickhob
Dec 4, 2019
Replies
4
Views
1K
Dec 6, 2019
kenmbz
P
Ford 4100 hitch cannot be held in position (always raises)
PhilipT
Dec 5, 2019
Replies
0
Views
604
Dec 5, 2019
PhilipT
P
Winged back blade power unit / pump
farm boy00
Nov 29, 2019
Replies
5
Views
1K
Dec 4, 2019
nyone
N
B
New Holland TC33d
b0508
Dec 4, 2019
Replies
8
Views
6K
Dec 4, 2019
dlctcg
D
P
Splitter
prenshaw2
Dec 3, 2019
Replies
8
Views
983
Dec 3, 2019
prenshaw2
P
Rear remotes troubleshooting question - BX 2380
tractorshopper
Jan 26, 2018
Replies
6
Views
4K
Dec 3, 2019
tractorshopper
N
Adding third valve to Joystick
Nicholas lewis
Dec 1, 2019
Replies
15
Views
3K
Dec 2, 2019
RNeumann
C
Ouch! Replace Nimco 2S-40272 Loader Ctl. Valve w Brand LV22 / Surplus Ctr. 9-7401?
caine
Oct 27, 2014
Replies
10
Views
52K
Dec 2, 2019
wdchyd
M
955 Power Beyond problem
mttop
Oct 14, 2019
Replies
3
Views
1K
Dec 2, 2019
mttop
M
Talk to me about the rear remote hydraulic valve type...mx5200
MechanicalGuy
Nov 12, 2019
2
Replies
34
Views
8K
Nov 30, 2019
MechanicalGuy
rockshaft / 3-point creeping down
WinterDeere
Nov 22, 2019
Replies
11
Views
3K
Nov 25, 2019
WinterDeere
Electric Actuator Retrofit
mikester
Nov 24, 2019
Replies
1
Views
598
Nov 24, 2019
oldnslo
O
8
Weird FEL behavior
83Ttype
Nov 9, 2019
2
Replies
32
Views
4K
Nov 23, 2019
PILOON
P
K
hydrulic pump for New Holland TC-24D
kevin3251
Nov 23, 2019
Replies
2
Views
872
Nov 23, 2019
oldnslo
O
G
Suction Filter
granitepeak
Nov 22, 2019
Replies
4
Views
1K
Nov 22, 2019
granitepeak
G
D
3 point and remote weak
Donnyncarol
Jun 25, 2019
2
Replies
36
Views
5K
Nov 22, 2019
Donnyncarol
D
G
Davis 185 / Backhoe Swing Cylinder
granitepeak
Nov 19, 2019
Replies
6
Views
3K
Nov 22, 2019
granitepeak
G
Boom out is 'jerky' at moderate RPMs - Kioti DK-40 Backhoe
Coyote machine
Nov 8, 2019
2
Replies
22
Views
4K
Nov 21, 2019
dfkrug
power beyond nomenclature plus
electrycmonk
Nov 20, 2019
Replies
5
Views
2K
Nov 21, 2019
WranglerX
K
TC-24D makking squeeling noise when in 4WD
kevin3251
Nov 21, 2019
Replies
4
Views
746
Nov 21, 2019
kevin3251
K
S
Thanks ptsg
swaynep1
Nov 21, 2019
Replies
1
Views
601
Nov 21, 2019
ptsg
0
kubota rtv 1100 hydraulic problems
01hunter570
Nov 17, 2019
Replies
8
Views
9K
Nov 20, 2019
oldnslo
O
R
JD 48 Backhoe slowly leaking fluid out of top port on valve
Robertpower3
Nov 20, 2019
Replies
3
Views
3K
Nov 20, 2019
wdchyd
Z
Couplings won't go in, no pressure either side, balls move freely
Z-Michigan
Nov 17, 2019
2
Replies
21
Views
9K
Nov 19, 2019
ruffdog
C
Massey ferguson polish 231 hydraulic question?
Charmed483
Nov 19, 2019
Replies
0
Views
568
Nov 19, 2019
Charmed483
C
M
Kubota L4150 low power at loader and 3 pt
mweller
Nov 18, 2019
Replies
0
Views
2K
Nov 18, 2019
mweller
M
G
Part sources to Rebuild 50's Hydraulic Cylinders
granitepeak
Nov 14, 2019
Replies
12
Views
3K
Nov 18, 2019
hslogger
H
C
Ways to slow down Front End Loader
Colonel Monk
Nov 18, 2019
Replies
9
Views
17K
Nov 18, 2019
RickB
C
Reading Hydraulic/tranny fluid levels
Chaos USMC
Nov 10, 2019
2
Replies
25
Views
3K
Nov 18, 2019
ericm979
E
Bobcat CT225 with TL7 Loader Leaking Curl Cylinder
SJay
Nov 17, 2019
Replies
0
Views
2K
Nov 17, 2019
SJay
T
Opinion on check valve in loader control valve
Tmod
Nov 15, 2019
Replies
7
Views
6K
Nov 17, 2019
Tmod
T
S
FEL
swaynep1
Nov 16, 2019
Replies
1
Views
584
Nov 17, 2019
ptsg
G
Hydraulic Cylinder Repair
granitepeak
Nov 14, 2019
2
Replies
24
Views
3K
Nov 15, 2019
granitepeak
G
C
What happens if you use thicker hydraulic oil?
catmanjan
Oct 13, 2019
Replies
9
Views
20K
Nov 15, 2019
catmanjan
C
Slow Initial Steering Response (Hydro)
Texasmark
Nov 6, 2019
Replies
14
Views
7K
Nov 14, 2019
Texasmark
2-channel snowblower control with 1-channel + power beyond tractor
WinterDeere
Nov 11, 2019
Replies
19
Views
4K
Nov 14, 2019
WinterDeere
T
Curl cylinder stalling engine
treelackey
Nov 13, 2019
Replies
15
Views
2K
Nov 14, 2019
ptsg
R
What happens if one accidentally puts pressure to the EXH port of this FC valve?
rfc143
Nov 11, 2019
Replies
5
Views
783
Nov 14, 2019
rfc143
R
Bobcat m600 change hydraulic fluid
fatjay
Nov 13, 2019
Replies
2
Views
5K
Nov 13, 2019
fatjay
K
Terex (asv) PT 80 Sluggish drive controls
Knucklehead11
Feb 6, 2018
Replies
14
Views
30K
Nov 13, 2019
Yoshiboldor
Y
J
New Holland 1630 hydraulic whine/jerky
Jtracker
Mar 5, 2019
Replies
17
Views
10K
Nov 13, 2019
Jtracker
J
Y
ASV RC30 Hydraulic Testing
Yoshiboldor
Nov 12, 2019
Replies
2
Views
6K
Nov 12, 2019
ptsg
L
Hydraulics, try pumping out the old fluid and air
Little1710
Nov 10, 2019
Replies
1
Views
682
Nov 10, 2019
Little1710
L
B
Has anyone tried used hydraulic oil in a drip torch?
bswiv
Nov 2, 2019
Replies
10
Views
5K
Nov 9, 2019
bswiv
B
A
1984 850 John Deere Wood Splitter?
amorace
Nov 5, 2019
Replies
3
Views
2K
Nov 7, 2019
Tx Jim
B
Credit where credit is due
Bsavulis
Nov 5, 2019
Replies
2
Views
847
Nov 6, 2019
wdchyd
B
Put a Hydraulic motor on a Badlands winch
bigrich954rr
Nov 3, 2019
Replies
13
Views
13K
Nov 6, 2019
kenMG42
K
Hydraulic brain bubble
Sberry
Nov 5, 2019
Replies
5
Views
1K
Nov 6, 2019
aczlan
A
L
Changing Hydraulic Oil Question - How to purge as much of the old fluid as possible
landrand
Nov 5, 2019
Replies
7
Views
5K
Nov 6, 2019
bridge4
FEL & 3pt hitch not working after oil/filter change
stump54
Nov 2, 2019
Replies
14
Views
3K
Nov 3, 2019
LouNY
Prev
1
Go to page
Go
62
63
64
65
66
Go to page
Go
273
Next
First
Prev
64 of 273
Go to page
Go
Next
Last
You must log in or register to post here.
Main
