tstex
Hello to all
I have not run my powerwasher for 2-3 yrs. So, before I tried running it, I did the following:
Added 93 octane gas and after a few pulls, she started, But, it would only stay running if the choke was left in the full position. when i started to move it to the "run" position, it would start to die so I moved it back to full choke. I operated it in the choke mode for about 1-2 hrs. When I ran her again, and tried moving from full choke to "run", it started to die and when i tried moving it back, she died. It would not start again.
Since it seems to be a fuel related issue, I pulled the carburetor and did the following:
I am open to all suggestions to get her running correctly.
Thank you inadvance,
tstex
- drained all the gas out of both gas tank and carburetor
- cleaned gas tank
- changed the oil
- checked air filter [does not have a fuel filter], it was fine
- cleaned carb (pulled main jet, and soaked in carb cleaner fluid)
- clean carb bowl & passage ways (see the enclosed video)
- pulled spark plug; it was badly fouled w a lot of blk carbon..so, cleaned and wire brushed it
- added new fresh fuel again
tstex
