Small issues on TC33D
/ Small issues on TC33D #1
Breech
Southern PA
2002 NH TC33D - Replaced a 1950 Ford 8N
Good morning,
2 small issues have arisen that I am curious if they are concerns:
1. Console between the steering wheel and hazard light button cracked. Easy to fix with JB Weld or something similar?
2. Temp Gauge is not working, never moves upwards (plowed snow for a few hours and still nothing moved). Is this something I should fix or just watch?
- I seem to remember seeing this is widespread and of no concern, but cannot remember.
Thank you all,
John
/ Small issues on TC33D #2
Good morning,
Thank you all,
John
The temp gauge should be repaired. Check the wiring to the temperature sensor, and the sensor itself.
Overheating is a good way to force another upgrade.
/ Small issues on TC33D #3
I'd either be repairing that temperature gauge or replace it with a standalone gauge to prevent overheating your engine.
/ Small issues on TC33D #4
As far as the dashboard if it’s plastic you might consider plastic welding it. You can buy a kit at Harbor freight or Amazon.
/ Small issues on TC33D #6
You need to confirm that the thermostat is working properly and not stuck open. Usually done with a infared thermometer or a long stemmed thermometer in the radiator cap. If it is warming up, then check the wiring between the dash and the sensor, near the thermostat.
/ Small issues on TC33D #7
I believe you can jump the temp sensor wire to ground and the gauge should move. Free test that you don't even need to start the tractor to try. You do need to turn the key though.
Ok all, thank you for the pointers and advice. Replaced both the thermostat and the sender unit, both had it! Shockingly, once done, the temp gauge on the dash started working again!!!
I really appreciate it!
/ Small issues on TC33D #9
Glad you were able to get the gauge working again.
Thank you. New one popped up today, I was working to get my bush hog connected and the height set with tractor running, idling. After finishing, a red pool of fluid was on the floor.
This was about a 12"x4" in size. I know that is hydauluc fluid, and quickly took some pics of where it was coming from, on the left side of the engine bay.
Normal? Expected? Bucket was also about 6 inches up off of the ground.
/ Small issues on TC33D #12
Dry everything off, and put a paper towel in there, and pinpoint exactly where the leak is coming from.
/ Small issues on TC33D #14
The only 2 "hydraulic things" that far forward are; 1) the hydraulic oil cooler, and 2) the power steering.
The cooler lines run up the left side and there are a couple sections of hose connecting the lines to the cooler. Possibilities there are a loose clamp on a hose, a leaking hose, a leaking cooler, or a leak in one of the oil lines, and the engine fan blowing the oil back over the front of the engine. The cooler lines and cooler are under the hydrostat charge pump pressure (around 70psi?). According to the service manuals for my 1520 and T1520, the charge pump sends oil first to the cooler, then through the hydrostat filter, then back into the hydrostat unit where the charge pump relief valve is located. This would mean that a plugged, dirt, or restricted filter would increase the pressure at the cooler.
Power steering reservoir, and lines, are on the other side of the engine but it is possible the fan could blow this oil around also.
A third possibility is a leak on the FEL that sprayed onto the engine.
Folks,
Any chance this is coolant? I thought coolant was green, but have learned there is a red version/type? It seemed to be a bit watery, less viscous like oil and more clear than oil.
Would that explain it better? It is a used machine, thought the coolant was green, but now I am unsure.....
/ Small issues on TC33D #16
Join the club. Yesterday, Sunday, the TC 33D was idling while I greased the rear deck mower. Saw spots similar to yours but smaller. After an investigation, determined the water pump was leaking and throwing brown liquid off the pulley. I can actually rattle the fan back and fort.
New, the plan. Not much on utube or TBN on pump replacement. Had my local dealer print out a few pages from the service manual on pump replacement involving radiator removal, coolant draining, etc. But there is also dealing with the oil cooler.
I'm going to do it, I've got the time and space. Looking at new pump, thermostat, coolant , fan belt and gaskets.
/ Small issues on TC33D #17
Folks,
The picture of the puddle sure looks like a water based fluid. Normally, fuel or oil will not stand up on the concrete like that. With a leak at the front of the engine, I would be looking at tightening a hose clamp to water pump.
/ Small issues on TC33D #18
The hydraulic fluid in my Massey and New Holland (TC33D) is clear.
Antifreeze can have a few different colors. Are you able to remove your radiator cap and see the color of the fluid in it?
/ Small issues on TC33D #19
The way we use to do it is tasting the leaked fluid and yes you call tell the difference coolant or oil.
