Small issues on TC33D
/ Small issues on TC33D #1
Breech
Southern PA
2002 NH TC33D - Replaced a 1950 Ford 8N
Good morning,
2 small issues have arisen that I am curious if they are concerns:
1. Console between the steering wheel and hazard light button cracked. Easy to fix with JB Weld or something similar?
2. Temp Gauge is not working, never moves upwards (plowed snow for a few hours and still nothing moved). Is this something I should fix or just watch?
- I seem to remember seeing this is widespread and of no concern, but cannot remember.
Thank you all,
John
/ Small issues on TC33D #2
Good morning,
Thank you all,
John
The temp gauge should be repaired. Check the wiring to the temperature sensor, and the sensor itself.
Overheating is a good way to force another upgrade.
/ Small issues on TC33D #3
I'd either be repairing that temperature gauge or replace it with a standalone gauge to prevent overheating your engine.
/ Small issues on TC33D #4
As far as the dashboard if it’s plastic you might consider plastic welding it. You can buy a kit at Harbor freight or Amazon.
/ Small issues on TC33D #6
You need to confirm that the thermostat is working properly and not stuck open. Usually done with a infared thermometer or a long stemmed thermometer in the radiator cap. If it is warming up, then check the wiring between the dash and the sensor, near the thermostat.
(50) UNUSED 3'x8' CORRUGATED METAL SHEETS (A64281)
(50) UNUSED 3'x8'...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
Landhonor Hydraulic Logging Winch (A66285)
Landhonor...
2014 Honda Accord Sedan (A61574)
2014 Honda Accord...
New/Unused CFG Industrial NT18K Mini Excavator (A65579)
New/Unused CFG...
2017 Dodge Charger Sedan (A61574)
2017 Dodge Charger...
