Messy oil changes
/ Messy oil changes #1
vic4news
Gold Member
Merrimack County, NH
Kubota B3030
I was always annoyed that my Kubota B3030 had a cross brace right under the engine oil drain plugs.
Made for a messy oil change. Recently my wife threw out a small oven pan which was the perfect size to fit under the drain plugs.
/ Messy oil changes #2
I suspect that cross member is part of the FEL mount and should protect one of these.
Check out Fumuto and EZ drain plugs, they are made to attach a drain tubing. You do have to know the correct thread size before shopping.
Drain the oil right into transport jugs.
/ Messy oil changes #3
Is Kubota the only one that runs a double dip type oil pan with two drain plugs, with the front driveshaft going up the middle?
When I first saw mine, I thought if that driveshaft ever comes loose like one did on a very old Jeep Cherokee of mine, it would wreck that pan in short order!
Good use of the pan! At least the concern that some had when I suggested putting those Fumoto drains on mine are eliminated with that cross member there, as they said it could easily get ripped off hanging down ... I was more looking to put them on my transmission as it holds 13 gallons, and that's a big HEAVY drain pan ...
/ Messy oil changes #4
OP: the above after market valve looks like a good alternative to the mess you describe, though i'd be cautious about adding the alternative plug plumbing and it's extension below the stock plug oil pan level in rough conditions.
personally, i'd stick with factory and your wife's pan. one mishap in plumbing or involving the plug extension, and all is lost.
maybe put plastic bag over cross member when changing & discard, less messy than dealing w/2 drain pans, regards
/ Messy oil changes #6
yup, way to do it. i do the same on my Kawi z turn changes that put contaminating belts at risk, etc.
OP: i'd be hesitant on after market engine drain plugs, keep simple
/ Messy oil changes #7
Need is the mother of invention or finding a cake pan. My M5640 isn't as bad as yours but was a pain until I made this
gg
/ Messy oil changes #8
IDK about that but I've worked on a Deere that has the transmission cooler wrapped around a non greasable ujoint on a driveshaft.
I mentioned it to a JD tech and he called it the donut.
/ Messy oil changes #9
I have a collection of metal and plastic pieces to guide waste oil to where I want it. For the op's cross member, I think a 2 or 3" diameter pvc pipe cut maybe 1/3rd down into a shallow "U" shape may do the trick.
/ Messy oil changes #13
On my larger tractor it has a valve like the Fumuto on the engine oil, and the radiator. It makes changing fluids easy! However the valves are well protected and so there is little concern with them, you just slip a hose on the valve and no mess. However on my low slung Massey 20C a valve would be a recipe for disaster, it is low slung and has the paint worn off the bottom of the oil pan from rubbing on the ground.
/ Messy oil changes #14
I have a couple of machines that make for messy oil changes, either drain or filter can make a mess. I just take some aluminum foil and make a spillway for the oil to follow, cheap and always available in "her" kitchen.
/ Messy oil changes
That’s what I’ve always done too. Using the the oven pan makes it easier now.
/ Messy oil changes #16
I’ve long since discovered the wonder of the topside extraction oil change. Beats crawling under & all the mess by miles, especially as I’m a lot older than I was. May not work with every oil pan configuration but I don’t miss drain pans and so forth.
/ Messy oil changes #17
I just go to the trash can and grab something cardboard like an empty 12 pack container, and use scissors to cut an appropriate sized rectangle piece. Stand it on the upper floor of the drain pan and lean it against whatever is in the way, under the drain plug. Works slick. Price is right.
/ Messy oil changes #19
That's what I do when I change the oil filter on my RAM pickup with the 5.7, as it's mounted right ABOVE the ELECTRIC power steering motor!
It's the only part on my 2015 truck that's not either dirty or rusty, from the regular yearly oil baths. :ROFLMAO: Hoping the 6.4L configuration on the 2500 will be a bit better, in that regard.
I've added a pipe nipple to more than one OPE engine, where the OEM had designed the thing with the oil plug just draining onto the chassis. My Huskee log splitter and Devilbiss power washer both come to mind, as both use a convenient 1/4-NPT pipe plug.
I haven't found any solution as elegant for the Subie engine on my Little Wonder leaf blower, since they use a crush washer instead of NPT plug, for oil drain. I usually just use a scrap of paper or cardboard folded into a V, to direct the oil toward the pan, on that one. It works, until one small slip or fumble makes a big mess.
Deere seems to be the only manufacturer of all the equipment I own, who actually takes a few seconds to think about and plan for oil changes. My mower has a valve screwed into the crank case, with a 90-degree spout on the drain, right over a hole in the motor mounting plate. Drains so clean and perfectly, I don't even need an oil pan, I can literally drain it straight into an old jug. Of course, they're competing on features over price, so it makes sense they're not cheaping out on the small details.
This is the type used by Deere. Much safer with a hex wrench needle valve closure, than the 1/4-turn lever types I see for aftermarket additions.
/ Messy oil changes #20
Yeah my JD ZTrak 960 with the Kawasaki 31 HP engine has a similar setup, I do add a hose to it though, as the outlet of the valve is just above the frame opening . . . Of course like you hint at ... At $17K+ they can afford to add a few nice "convenience" type additions ...
