Shifting into neutral
/ Shifting into neutral #1
Kiowner
New Hampshire
Kioti 3520SE Cab, Kubota L5740 Cab, JD X540
Well, I asked about bypassing the neutral start requirement and received several responses why I shouldn't, but no responses to how. All inputs and possible safety issues appreciated, thank you.
My initial thought was to disable this feature because of the difficultly I often experience shifting into neutral in order to start the tractor. It is often difficult to move the lever into a neutral position to start the engine. I do not like forcing this to go into position and will do whatever to get it into the proper gear position when the engine is running. But what to do when I have to force it into neutral just to start the engine?
/ Shifting into neutral #3
Plan ahead. I park my CK3510 in neutral with the parking brake engaged. Everything lowered to the ground to help prevent it rolling off. Then I can start the tractor easily.
This is exactly what I do. 🍻
/ Shifting into neutral #4
So, Ck2610 here, but basically apples to apples. I had every intention of disabling the neutral and seat safety at first. Until, our German Shepard tried to jump up, as I was getting down, and he hit the forward peddle, enough the tractor moved forward about 8", as i was one foot on, one foot off.
It kinda an annoying safety feature, but after that, I thought, probably better leave it intact. Now, im not saying dont do it, just why I chose to not do it.
/ Shifting into neutral #5
So, on the sticky H-N-M-N-L; even at 210 hours, mine still can be a pain. Now, rather then force it, while in neutral, if it doesnt want to move to medium, just bumping the F peddle, often allows it to go in easily. Kinda annoying, extra step, but if your having trouble...
/ Shifting into neutral #6
Some tractors are picky about clutch adjustment when the engine is not running, which makes shifting in/out of gear draggy-so-to-speak. They seem to shift normally when running though. a friends Kubota HST comes to mind.
/ Shifting into neutral #7
The KIOTI Owners Manuals for the HST Units all recommend bumping the Forward and Reverse HST Pedals, with the clutch out, if the unit has a clutch pedal. The other "bump" that works well is to bump the joystick lever. The rocking motion the loader puts on the tractor loosens the transmission.
Hope this helps.
Thanks, I'll try all of your suggestions.
I also have a Kubota and it also can be difficult to shift without the engine running, but it will start without being in neutral so this isn't an issue with that tractor.
2012 PUMA BUMPER PULL (A67714)
2012 PUMA BUMPER...
2018 GENERAC MOBILE PRODUCTS MLT6S (A67714)
2018 GENERAC...
BOAT MOTOR (A66738)
BOAT MOTOR (A66738)
ALLMAND MAXI-LITE II V (A68842)
ALLMAND MAXI-LITE...
Caterpillar 70in Loader Forks and Frame Attachment (A61572)
Caterpillar 70in...
2014 Ford F-150 Ext. Cab Pickup Truck (A66736)
2014 Ford F-150...
