T574 DPF lights on again
/ T574 DPF lights on again #1
nepa
Forest City, PA
Mitsubishi 180D, Jinma 284 sold, Kubota BX2660, IH Cub, Case 580CK, Minneapolis Moline 4 Star (sold), TYM 574, Furukawa FX-040
Yes, same lights, same tractor, only 10 hours after resetting, and neither TYM or the dealer care. I can not recommend anyone buy a TYM tractor. My first 2018 T574 had the DPF and MIL lights come on after using the brand new tractor for only about 10 hours. It was a 30 month ordeal with about 20 visits to my farm by the dealer and the lights coming on five times more in less than 90 hours that the PA attorney generals office was instrumental in TYM replacing the tractor in 2022. My 2022 T574 had the same lights come on a year ago with about 90 hours on the clock. My dealer and TYM was notified. Neither ever responded about fixing the tractor.
The great people at TBN wrote about a procedure to reset the lights. It worked. But now, with only about 10 additional hours on the clock, the lights are on again. I was in the middle of a one hour project unloading and moving pallets with forks when I got out of the cab to adjust the forks and when I got back in the lights were on. No fathomable reason what so ever.
My dealer said that the first 30 month ordeal made him sick. So now he and TYM just ignore this issue. I am sick too because I am out the money. So to be certain that you do not go through what I am, do not buy a TYM.
/ T574 DPF lights on again #2
That sucks. Id probably remove the damn thing thing and run it.
Mine is three years issue free. This is wild it has happened on two units you have owned.
I know. Really hard to believe. I had a theory at one time. That after running the tractor for hours brush hogging, a lot of chaff would build up from the radiator to the 3 point. When I got it back to the barn I used an electric leaf blower to get the chaff off while the engine cooled down running. My theory was that I was cooling off something abnormally fast. My theory is obviously wrong since it happens in the middle of running.
/ T574 DPF lights on again #4
I've read your other posts on this and it's tough situation for sure and I feel for you.
It may have been mentioned, but is the DPF system computerized or not on this model? Either way, you'd think it would be an easy troubleshoot with respect to is there really a problem or is the system getting bad/false/no inputs.
It would be nice if TYM manned up a bit at this point and gave you either some sort of an answer or a "cease and desist" 'we did what we could, never bother us again on this particular problem' letter. If I recall correctly, the dealer and TYM people made multiple trips to your house, picked up and delivered your machine free many times and gave you a brand new 2022 tractor to replace your 2018. In my opinion, that is above and beyond what most manufacturers would do, given the situation.
I can't say I'm a huge TYM fan given what I dealt with just with trying to take delivery of my little T224, but I knew I wasn't buying a Deere or a Kubota and I hope they do better in the future.
I have no idea if the DPF is computerized. Including the original, I think that the first tractor had 5 DPF controllers because that was the most likely culprit. I can not be lenient to TYM because they use their 6 year warranty as a selling feature. My experience proves that to be a big lie. Also, after 30 months I believe that the only reason they replaced the tractor was due to the PA attorney general office was on their case and TYM has a big facility in PA.
/ T574 DPF lights on again #6
If the DPF system has a controller, it's under some form of computer control. Probably not the route you want to go, but It would be awesome if someone like Ivan from Pine Hollow Diagnostics could come take a look at it. Someone like that would likely have it diagnosed properly in under an hour. He's out of PA. There's probably tons of mobile equipment techs that would have it figured out in no time as well. Problem is, any of that would be on your dime. As you've discovered, any really good TYM specific tech/diag service is far and few between, if it even exists.
I would just like to add that this problem is covered by the warranty. The dealer says he can do nothing without authorization from TYM. He spoke to and emailed TYM 12 months ago and no one has responded. The dealer says that the ordeal with the first tractor made him sick so he wants me to find another dealer to handle a problem which should not be their responsibility because they did not make the profit in the sale. Frankly, they have worn me out except for letting others beware. I will do that every time that I need to reset the error message. Are you listening TYM?
/ T574 DPF lights on again #8
The T574 uses a mechanical injected engine, meaning, it just really needs 1 wire for the shutoff solenoid to work.
The DPF controller is just that, a DPF controller, to keep track of how clogged the DPF is and then ask for a regen when it's due time.
Technically, it could all fall off and the engine couldn't be any happier. Less fuel consumption, less restriction, a little bit more power.
Of course, this should've been fixed by the dealer, which so far, I've only read about DPF controllers being replaced. It could also be a bad exhaust valve causing the issue or even a sensor on the DPF.
Besides on site work, the first tractor was hauled back to the dealership for extensive work twice. Ultimately, I think that every DPF related part was replaced except the dash board display. Still, this is not an excuse for ignoring the current problem for 12 months.
/ T574 DPF lights on again #10
Sorry that's happening to you. I have the same tractor and zero problems, to date.
I know it's annoying, but it also isn't stopping you from using the tractor. With most modern tractors, that would put your machine into limp mode, making it useless.
/ T574 DPF lights on again #11
With just 20 hours on my TYM 547 the DPF lights flashed. I did a regen and the lights still flashed. Contacted the dealer and they suggested doing another regen. That did not help. So another call to the dealer. After a few days the dealer got back with me and told me it may be a glitch in the sensor and just drive it. I have done that for over a year and the lights are still flashing and the tractor works fine! I really like the TYM tractor, but their service network sucks.
/ T574 DPF lights on again #12
DPF system can sometimes be tricky.
I dont know exactly, but we have a fleet of + 50 Deutz TCD3.6 engines with DPF.
Sometimes after a regen they still complain they need a regen.
A few solutions are:
Disconnect the battery and also engine oil service reset needs to be performed to make the DPF happy again.
The main culprit to dpf regens are engine idleing ( warm up and cool down) and exhaust systems that not get warm enoug and long enough.
These engines needs to work.
/ T574 DPF lights on again #13
On those engines if there is no Beep sound then usually the light just needs to be reset. of course if there is a defect somewhere then that might not help anyways....
/ T574 DPF lights on again #14
I'm curious, with DPF light on with such low hours. Would you mind describe your overall experience with tractors and equipment? What rpms do you operate under? And do you idle for longer than 10-15 minutes besides the warm up time on cold start?
/ T574 DPF lights on again #15
Was not hard to remove the DPF on my 454 so it shouldn't be to hard on the 574. I removed mine at 12 hours and blocked off the egr. Now 1000 hours. Only problem I've had with the computer was 2 little fuses in the wiring harness. They lay in the bottom where they stay wet and dirty. When one or both corroded, the tractor went into limp mode and had no power. Took a while to figure out what was wrong, but I was lucky that I got a TYM mechanic to tell me to check them. They were hard to see and get to. I moved them up high out of the wet spot. Have 1000 hours and no more engine problems. But ever seal that can leak is leaking. I just let them leak.
/ T574 DPF lights on again #16
You've been gone for awhile Bud...Glad to see you're back and I hope your absence wasn't due to any health issues! Greg
Hi TractorTYMe. The tractor never idles for more than a minute or two after warm-up. 95 percent of the running time is at 2400rpm with a brush hog, finish mower or 75 inch snow blower. A very short amount of time is with QA pallet forks at various speed. Warm up time is done with the info button pressed and the tractor not put into service until the digital temperature display reads 60 Centigrade or higher. Generally, normal operating temp is about 74. When the radiator collects chaff and the temp reaches 90 I clean it out. Per owners manual, a hot engine is allowed to cool down a few minutes before shutting off at which time I clean off the tractor with an electric leaf blower. My first 574 that had the DPF lights on 5 times in the first 100 hours on the clock still looked like showroom condition when they took it back.
/ T574 DPF lights on again #18
I've only been visiting this board a short while, but during this time, I've seen very few complaints about TYM DPF problems, and the one's I've seen have all been from you.
Given that you've had the same problem very quickly with two new tractors when most owners never have any problems (or even any regens!), I wonder what your two tractors have in common that caused them to have problems?
/ T574 DPF lights on again #19
It is anomalous. Most people report running the TYM diesel hundreds of hours without as much as a regen request from the tractor.
It's not like 15 hours to 50 hours difference. It's literally hundreds of hours difference. It's had me perplexed for sure.
I mean mine is a 20 series Branson/TYM, but as far as I know the only difference is the turbo on the 574 vs my 4820.
Now, the turbo does remove downstream heat and pressure from the exhaust flow, so could that result in more soot build up? Maybe so
/ T574 DPF lights on again #20
That's a good point. I was just reading a post on one of the Facebook groups and most people reporting at least 400/450 hours for the first regen. Some even 1000 hours. This on 474, 494 and 574 models.
2006 Ford F-750 Terex Commander C1017 Digger Derrick Truck (A64194)
2006 Ford F-750...
UNUSED ATSPOWER PROPANE PATIO HEATER (A64281)
UNUSED ATSPOWER...
2025 Swict 66in Bucket Skid Steer Attachment (A61572)
2025 Swict 66in...
Deutz 4-Cylinder Air-Cooled Industrial Diesel Engine (A63689)
Deutz 4-Cylinder...
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
2011 WESTERN STAR 4900SA (A63569)
2011 WESTERN STAR...
