Wasting Fuel or saving the engine?
/ Wasting Fuel or saving the engine? #1
Tkekic
Canfield, Ohio
Massey Ferguson 1648 with a Massey DL130 Loader, Massey 1455v, NH 477 Haybine, NH 268 Hayliner, Pequea Rotary Rake 1140, Pequea Turbo Tedder TT2000, Dixie Cjopper Classic zero turn, Kubota RTV900XT, Woods BB72x 3pt rotary mower, Woods B96 mower
Kubota M7060. Been really cold here in NE Ohio. The 7060 has a manure spreader on it for the winter. In the summer I empty the manure on a pile out in our pasture. Engine reaches operating temp. in a short time. In the winter I change the job. Question is, am I wasting fuel by keeping the engine running until it reaches normal operating temp? I do this by running it at 1500rpm but in the summer I use 6th gear low range. Now in the cold I still run it at 1500rpm but in 3rd or 4th gear. I take the long route to be sure the engine reaches normal operating temp. Am I wasting fuel? Or is a good idea to bring the engine up to temp before parking it?
/ Wasting Fuel or saving the engine? #2
IMO, it's a good idea. I even let the tractor idle longer in the winter even though the Auto OEMs will tell you it's better to start and get moving as fast as possible.. Which is only really because allows the cat/dpf/scr to get up to temp faster, not because it's actually better for the engine itself.
/ Wasting Fuel or saving the engine? #3
My tractor doesn't even reach "normal" operating temperatures after blowing snow for a half hour at 20°. I would not worry about it, unless you are somewhere that ambient temps are typically well below 0°F.
/ Wasting Fuel or saving the engine? #4
I am not sure I understand... you want to reach temp before parking it once your task is completed ? if that's the case is so no there is no used for that.
/ Wasting Fuel or saving the engine? #5
I think the question is based around the idea that an engine should reach operating temp before it's shut off.
My (uneducated, undegreed) opinion is that, no, it's not necessary or even that helpful. Running an engine long enough so that it's up to a temp high enough to evaporate condensation would be advisable (again - my uneducated, undegreed opinion), but unless done as a normal matter of course, it should not be notably detrimental.
/ Wasting Fuel or saving the engine? #6
Nothing to disagree here … faster within reason a engine reach temp better it is but if it doesn’t it doesn’t…
/ Wasting Fuel or saving the engine? #7
I run the engine at 1500 rpms for a few minutes, then gently operate my tractor until it it warms up a little more.
I ALWAYS get it up to operating temp before shutting it down.
/ Wasting Fuel or saving the engine? #8
FWIW, a diesel engine should be ran for at least 20 minutes after it reaches operating temperature, otherwise any crankcase condensation does not evaporate completely.
That is from Cummins engine operating manual.
Using 1,500 RPM(high idle) is good, an engine should never run at low idle for more than 10-15 minutes.
/ Wasting Fuel or saving the engine? #9
You could also change the engine oil prior to the service interval. I don't believe that hydraulic oil will reach operating temp in those cold days.
One thing that will help is having a block heater..no fuel needed and there pretty cheap.
2024 Scag Cheetah 61in. Zero Turn Commercial Mower (A61567)
2024 Scag Cheetah...
2011 Warren 48ft. T/A Walking Floor Trailer (A61568)
2011 Warren 48ft...
2003 Dodge Ram 4x4 Ext. Cab Pickup Truck (A59230)
2003 Dodge Ram 4x4...
UNUSED JCT 84" HYD GRAPPLE BUCKET (A62131)
UNUSED JCT 84" HYD...
2016 CATERPILLAR 416F2 BACKHOE (A63276)
2016 CATERPILLAR...
2022 CATERPILLAR 299D3 SKID STEER (A62129)
2022 CATERPILLAR...
