New metal roof leaking, need advice.
/ New metal roof leaking, need advice. #21
Also, what does the detail look like where the roof changes pitch (at the peak and the gambrel)? Snow/rain can blow back up into that cap piece and then the water can run back down the roof under the panels until it finds a convenient spot to drip. There are supposed to be fillers in there to keep the snow/rain from blowing back up under the peak or gambrel pieces.
/ New metal roof leaking, need advice. #22
My pole barn with the metal roof has no leaks when it rains. But when conditions are right the condensation is so heavy you'd swear it was raining inside. (Metal roofing is fastened down to wooden beams, nothing under the metal so it acts like a solar water collector - something I learned to construct in survival training.)
/ New metal roof leaking, need advice. #23
This covering was put over an existing roof so it would take a LOT of condensation to experience significant leakage.
Pretty sure this is not condensation.
/ New metal roof leaking, need advice. #25
True, but he did say that the area with the skylights leaked the most and the rest of the roof also leaked here and there already as well..
/ New metal roof leaking, need advice. #26
/ New metal roof leaking, need advice. #27
Boy those roofers were not framers by any stretch of the imagination.
The skylight fix did not fix your problem. They did something wrong there, It's too bad we can't see what they did on the top side.
Ya.. most roofers aren't. Looks like they just went over the replacement plywood with the furring strips and then the metal, no paper.
I would like to see the actual flashing and trims, and whether they used the foam closure strips and butyl tape. That said, you *can* get quite a bit of condensing moisture under the metal. If it was there, froze then thawed all at once..? This is why the roof itself is still supposed to be protected from moisture. If the original shingles are bad, they get tore off and an underlayment gets put down like any other roof.
/ New metal roof leaking, need advice. #28
If I understand, the roof has three different slopes. The skylight looks like it's on the middle section. Wherever it is, I would guess the roofing is not properly flashed between the slopes above the skylight, allowing moisture to move under the roofing and run down to the skylight where it leaks through.
I would get the roofer out there and try to get him to fix it. Pretty sure it wasn't done correctly.
/ New metal roof leaking, need advice. #29
I'm not a framer either. But I could have framed up that skylight hole much better than that
/ New metal roof leaking, need advice. #30
Well, i
There’s one thing great about steel roof. It can only leak in a few places. Screws sometimes miss which is easily plugged in a dab of RTV and along the edges. A screw leak is usually tiny. Seams on a steel roof are so self aligning its real hard to screw it up and it’ll show up visually .
If it’s not insulated up there you should be able to easily see where it’s coming down from ,water only flows down not up . It can’t go up except in a really unusual circumstance, like an ice dam. Even then it won’t go very far from the source.
Just looking at what you’ve got going on there my first question would be is it coming down from the very top of that seam where they meet at the base of the gambrel. Is there sufficient overlap and or flashing behind that seam? That would be my first suspect.
Get with that roofer before things dry up. He should be able to find it and trace it source quite easily and above all remember one thing, BE NICE🤗. Be nice until it’s time not to be nice anymore.
2014 Bobcat T650 (A60462)
2014 Bobcat T650...
2020 Deere 750K LGP (A53317)
2020 Deere 750K...
JLG 1930ES ELECTRIC SCISSOR LIFT (A59823)
JLG 1930ES...
40' High Cube Multi-Door Shipping Container (A60463)
40' High Cube...
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
ALLMAND LIGHT TOWER (A60736)
ALLMAND LIGHT...
