Kubota b7100 wiring to glow plugs seem to get killes
/ Kubota b7100 wiring to glow plugs seem to get killes #1
randyschnettler
Kubota b7100
Newbie here just bought B7100 other sure what year.
Problem is wiring to ignition glow plugs thought it was the battery 2017 so I replaced and I messed with the wires and it came on.
I started today and it clicked it turned and dead
No red light, so messed with wires and glow plug light comes on but when I turn key to the left no light.
Any help would be great full.
/ Kubota b7100 wiring to glow plugs seem to get killes #2
Start with the wiring diagram in the service manual for your machine. Shortcuts likely will not fix the problem.
/ Kubota b7100 wiring to glow plugs seem to get killes #3
Nice little tractor with all the right attachments.
Glow plugs are useful to help start a cold engine in cold weather.
If the temperature is above freezing, I'd probably begin by disconnecting the glow plugs and see if it will crank and start without using them.
/ Kubota b7100 wiring to glow plugs seem to get killes #4
I bought my B7100DT new in 1978, even in the summer with 80/90 degrees, if it sits for 5 minutes or more, I have to give it 3-4 seconds of glow plugs to start. For a cold start in the summer I give it about 20 seconds. I no longer use it in the winter.
/ Kubota b7100 wiring to glow plugs seem to get killes #5
I have a B7200 HST 2WD.
I've pulled the dash off several times to make repaires to wiring and switch gear.
It's not hard, Steering wheel and four screw fasteners. You Will need to have a look!
/ Kubota b7100 wiring to glow plugs seem to get killes #6
The B7100 is a classic. It's simple, as reliable as a hammer, rebuildable forever, and will probably still be hard starting for the next half century, too.
I imagine you know that hard starting is typical of low compression. OTOH, even a diesel that is down on compression often works fine once started.
It's hard to be critical of a nearly 50 year old tractor that only wants to work in warm weather.
I'm much the same.
rScotty
/ Kubota b7100 wiring to glow plugs seem to get killes #7
I'm much the same.
rScotty
I think it has 1300 hrs, runs fine, plenty of power and uses no oil. As long as I can remember it has always been like that.
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
MIDDLE BUSTER PLOW (A60430)
MIDDLE BUSTER PLOW...
2021 TAKEUCHI  TB260 (A58214)
2021 TAKEUCHI...
UNUSED KJ K3325G 33' X 25' DOUBLE GARAGE (A60432)
UNUSED KJ K3325G...
UNUSED RAYTREE RMBD72-72" HYD DRUM MULCHER (A60432)
UNUSED RAYTREE...
2002 Ford Thunderbird Convertible (A59231)
2002 Ford...
