Kubota b7100 wiring to glow plugs seem to get killes
/ Kubota b7100 wiring to glow plugs seem to get killes #1
randyschnettler
Kubota b7100
Newbie here just bought B7100 other sure what year.
Problem is wiring to ignition glow plugs thought it was the battery 2017 so I replaced and I messed with the wires and it came on.
I started today and it clicked it turned and dead
No red light, so messed with wires and glow plug light comes on but when I turn key to the left no light.
Any help would be great full.
/ Kubota b7100 wiring to glow plugs seem to get killes #2
Start with the wiring diagram in the service manual for your machine. Shortcuts likely will not fix the problem.
/ Kubota b7100 wiring to glow plugs seem to get killes #3
Nice little tractor with all the right attachments.
Glow plugs are useful to help start a cold engine in cold weather.
If the temperature is above freezing, I'd probably begin by disconnecting the glow plugs and see if it will crank and start without using them.
/ Kubota b7100 wiring to glow plugs seem to get killes #4
I bought my B7100DT new in 1978, even in the summer with 80/90 degrees, if it sits for 5 minutes or more, I have to give it 3-4 seconds of glow plugs to start. For a cold start in the summer I give it about 20 seconds. I no longer use it in the winter.
/ Kubota b7100 wiring to glow plugs seem to get killes #5
I have a B7200 HST 2WD.
I've pulled the dash off several times to make repaires to wiring and switch gear.
It's not hard, Steering wheel and four screw fasteners. You Will need to have a look!
/ Kubota b7100 wiring to glow plugs seem to get killes #6
The B7100 is a classic. It's simple, as reliable as a hammer, rebuildable forever, and will probably still be hard starting for the next half century, too.
I imagine you know that hard starting is typical of low compression. OTOH, even a diesel that is down on compression often works fine once started.
It's hard to be critical of a nearly 50 year old tractor that only wants to work in warm weather.
I'm much the same.
rScotty
/ Kubota b7100 wiring to glow plugs seem to get killes #7
I'm much the same.
rScotty
I think it has 1300 hrs, runs fine, plenty of power and uses no oil. As long as I can remember it has always been like that.
2018 International WorkStar 7500 Aquatech B-15 Combination Sewer Jetter Vacuum Truck (A59230)
2018 International...
2009 IC Corporation PB105 School Bus (A59230)
2009 IC...
2018 Ford Fusion Hybrid Sedan (A59231)
2018 Ford Fusion...
2013 BIG TEX 20 T/A GOOSENECK TRAILER (A60736)
2013 BIG TEX 20...
2016 KOMATSU D65PX-18 BULL DOZER (A58214)
2016 KOMATSU...
2022 Ford Explorer AWD SUV (A59231)
2022 Ford Explorer...
