how to drill out stuck PTO shear bolt?
/ how to drill out stuck PTO shear bolt? #31
I could care less what the manufacturer instructs for most things.
I take pride in common sense and successful outcomes.
Your experience may be different! ;-)
Only a problem if a warranty claim is made.
I’ve seen plenty denied because manufacturers instructions disregarded…
/ how to drill out stuck PTO shear bolt? #32
The shear bolt on my 6' rotary cutter is really stuck. Cut the bolt head off and tried driving it out from both sides. The bolt will only move about 3/8" in before it won't go any further.
It isn't rusted in place. I'm guessing it is partially sheared?
At this point, I'm guessing my only option is to drill it out. It's a 1/2 inch regular bolt.
How do I drill it out without boring out the PTO collar and the PTO shaft by mistake? I would think I would first need to drill a pilot hole, but I would probably get it off center.
View attachment 4567249View attachment 4567250
Hi,
I had a somewhat similar experience a while back and had decent luck doing this - Soaked the metal with penetraiting fluid over a period of a week and warmed the metal with a hair dryer before applications. In my case it was a broken bolt but had an uneven surface on the face as does yours. I used a larger drill bit to clean up the face to give it a clean cone and then using the cone as the new center used a bit about 1/3 the diameter of the bolt and drilled through. It takes some time and you have to be carefull not to break the bit so keep adding cutting oil and go easy. Once through step up the bit another size or two and do it again. The bigger hole allowed me to get an easy-out into the bolt and work it until it loosened up. Kept tapping it with a hammer and appling penetraiting fluid and warming it along the way. If you can get your pin to turn it should knock it out. I am assuming this is a straight pin without a step in the shank but even with that just start on the smaller end if you know which one it is. Good luck with it.
/ how to drill out stuck PTO shear bolt? #33
I'm wondering if you had tried to back the bolt out before you ground the head off. If not, you could try (if you have the capability) welding a nut on the end of bolt and backing it out. If the other end of the bolt is close enough, you could try the same thing there.
The continuing struggle with shear bolts is why I purchased a clutch, put a grade 5 bolt in place of the shear bolt and haven't looked back.
/ how to drill out stuck PTO shear bolt? #34
So one of the halves is technically a shaft, while the other has the bore when the shaft slides into. Both parts get a rounded groove machined.
Then the half with the bore, has an hole machined on the side, this hole is used to insert various bearing balls that will lock both halves together.
Finally, the hole is plugged using a grease fitting as these parts need to be greased since those spins when the bolt is sheared.
Hopefully my explanation made sense. I can make a quick 3D model if needed.
EDIT: Here is a repair manual for one of these. You can see how it's put together.
(y) Thanks for the description
/ how to drill out stuck PTO shear bolt? #35
Afternoon all;
I'm going to get on a soap box for a bit.
It has become a common reference to call a bolt securing a PTO yoke to an implement shaft a SHEAR bolt.
I'm old school that never used to be called a shear bolt it was a connecting bolt.
The design of shear bolts was normally a single shear on the untreaded portion of a bolt in a flange. There used to be commonly available charts as to the ft. pounds of torque of the common sizes and grades of bolts used as shear bolts. This value is highly dependent on the distance the shear bolt location is from the centerline of the rotating shaft. I was having a hard time trying to locate one of those charts or the information in an easy to read and display manner. I did fine the information on the BONDIOLI & PAVESI web site and catalogs.
They offer many shear bolt PTO yokes that can pass from 650 Nm to 9000 Nm or 480 ft. pound to 6638 ft lbs. of torque being transmitted before being sheared.
On this page the R1 distance is the distance from the shaft center line to the shear bolt center line.
Then this page lists the sizes of the shear bolts for each different PTO yoke to achieve the desired torque transmission
Lots of information on shear bolt PTO flange yokes.
Most people will not care, but it is a peeve of mine when a product is not being used in the proper manner (as far as farm equipment goes).
SO NO A CONNECTING BOLT HOLDING A PTO YOKE ON AN IMPLEMENT IS NOT A SHEAR BOLT,
I don't give a damn what it has been bastardized to from the cheaper equipment manufacturers.
End of rant, all have a good day.
/ how to drill out stuck PTO shear bolt? #36
Afternoon all;
But what US manufacturers do is using gearbox with a smooth input shaft, for some weird reason and then use a through bolt as shear bolt. A circlip is what prevents the PTO shaft from coming out of the input shaft of the gearbox after the bolt is sheared.
Once the bolt inevitably shears, then the operator has to fight the sheared section in the input shaft, a terrible design. A standard 6 spline input shaft and these shear bolt yokes would solve many issues and reduce downtime by a lot.
If you're saying that that is not a shear bolt, then they offer no driveline protection at all? Which would be even worse.
/ how to drill out stuck PTO shear bolt? #37
A shear pin yoke is available in the shaft size being used which is what the manufactures should be using.
Besides which what is the double shear of a 1/2" bolt? compared to what the shear factor should be to protect a gear box.
So a half inch grade 5 bolt has a single shear of 6300 to 8100 ft. lbs. double that for being in double shear.
In my mind that is not protecting a gear box.
In my opinion the reason that these half inch bolts finally break is all the shock loads accumulated over the life of the bolt, the shock starting and stopping then the impacts while being used.
As far as I'm concerned anyone that doesn't use a properly maintained slip clutch or a properly sized shear flange is just asking for excessive wear and damage.
/ how to drill out stuck PTO shear bolt? #38
Afternoon all;
I've got a shaft like that on my woodmax woodchipper but nowhere in the manual does it specify which end attaches to the tractor pto. Both ends fit either end? I "assume" the sheer bolt end attaches to the implement pto stub? Have had zero problems but would really like to know for sure where it's supposed to attach. Thanks.
/ how to drill out stuck PTO shear bolt? #39
Some where there is a standard on that. I have seen it and it was related to the shielding and so called personal safety. The more common is on the implement end as that is usually more open and easier to work with.
/ how to drill out stuck PTO shear bolt? #40
I've heard it said,......
Use a grade five bolt, they shear off more cleanly and don't result in the distorted bound up mess as this example shows.
But who really knows, that could be a grade 5 bolt, and the shaft and collar holes may be all wallowed out.
FWIW, I use gr 2 bolts, but decided to try a gr 5 after reading here. The gr 5 bolt broke on both sides, but one end of the bolt was long enough it cut a groove in the cast iron PTO end. I promptly went back to gr 2 @ $1.55 ea. including Nylok nut.
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
Frontier AV50H (A60462)
Frontier AV50H...
17102 (A56859)
17102 (A56859)
2019 FORD F-150 XL EXT CAB TRUCK (A59823)
2019 FORD F-150 XL...
2019 GALLEGOS TRAILER PNEUMATIC TRAILER (A60736)
2019 GALLEGOS...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A52707)
2007 CATERPILLAR...
