how to drill out stuck PTO shear bolt?
   / how to drill out stuck PTO shear bolt?
I'm wondering if you had tried to back the bolt out before you ground the head off. If not, you could try (if you have the capability) welding a nut on the end of bolt and backing it out. If the other end of the bolt is close enough, you could try the same thing there.
The continuing struggle with shear bolts is why I purchased a clutch, put a grade 5 bolt in place of the shear bolt and haven't looked back.
The bolt had enough bend in it that it wouldn't back out, either.
If there was ever a good sales pitch for buying a slip clutch, my experience fighting this bolt to remove it might be one.
   / how to drill out stuck PTO shear bolt? #42
As mentioned, flood both sides with PB Blaster or equivalent. I keep a spray can under the seat next to the wasp spray. The remaining part is probably bent now. Working it back and forth with an air hammer shouldn't cause a problem as long as it's lubed. Or as the guys said, mow until it's completely sheared. I lube the bolt shanks with anti-seize when installing new bolts to help with future bolt removal. Please let us know what works.
   / how to drill out stuck PTO shear bolt? #43
   / how to drill out stuck PTO shear bolt? #44
So a half inch grade 5 bolt has a single shear of 6300 to 8100 ft. lbs.
10k-14k Lbs according to your chart.
I have that same chart
   / how to drill out stuck PTO shear bolt? #45
FWIW, I use gr 2 bolts, but decided to try a gr 5 after reading here. The gr 5 bolt broke on both sides, but one end of the bolt was long enough it cut a groove in the cast iron PTO end. I promptly went back to gr 2 @ $1.55 ea. including Nylok nut..
So, you use a shorter grade 2 bolt than the grade 5 you tried?
   / how to drill out stuck PTO shear bolt? #46
10k-14k ft/lb according to your chart.
I didn't see that chart but suspect any reported shear ft-lbs would be torque around the bolt's axis, like with a wrench.
Torque to shear a bolt in this PTO setup would only be PTO torque, and would have to also specify the distance between the shear plane and the shaft centerline. That would work out to pounds force, not foot-pounds.
   / how to drill out stuck PTO shear bolt? #47
Sorry, I meant Lbs. not ft/lbs. I corrected it.
   / how to drill out stuck PTO shear bolt? #48
Same length,just softer bolt. I want the easiest to replace, cheapest part to be the first to break.
2008 CATERPILLAR 420E BACKHOE (A59823)
2008 CATERPILLAR...
(15) WOOD PALLETS (A60432)
(15) WOOD PALLETS...
2006 Club Car Carryall 2 Electric Utility Cart (A59228)
2006 Club Car...
2011 Toro Multi Pro 1250 Sprayer Cart (A59228)
2011 Toro Multi...
2019 Merlo TF 42.7 (A60462)
2019 Merlo TF 42.7...
SKID STEER ATTACHMENT SIFT BUCKET (A58214)
SKID STEER...
