Loader boom cylinders uneven
/ Loader boom cylinders uneven #1
Ken P
North Granby, CT
Kubota B2410
Folks - I was taking my loader (LA 352) off my B2410 today (to put on the snowblower) and noticed that the boom cylinders were uneven. That is, the clutch side boom cylinder was pushed out more than the left. It was very difficult to remove the loader, also - one side came off and the other didn't, until I horsed around with it quite a bit. Nothing leaking. No accidents or problems up until today.
Could anyone point me to how I go about diagnosing and (hopefully at home) repairing? Much appreciated -
Ken in North Granby, CT
/ Loader boom cylinders uneven #2
Sounds to me like the gland nut threads are stripped, then the hyd. oil got out of balance in the cylinder.
/ Loader boom cylinders uneven #3
The cylinders are self equalizing, the mounting brackets/loader assembly are what keep them even.
I assume this issue was before the loader was removed.
If so, its possible the mounting brackets have shifted, also possible the frame has been tweaked. Brackets would be my.first guess though.
You can reset them my parking on a hard flat surface (preferably flat concrete) and with the loader mounted and bucket grounded, lossen the mounting bracket bolts then re-torque them to specs.
You may have to move the bucket a little while the bolts are lose to shift things around.
Sent from my SM-S921U using TractorByNet mobile app
/ Loader boom cylinders uneven #4
In addition to what @TMGT states, it's possible to damage the crossover tube between the loader arms. Similar symptoms will result, and the damage is not always obvious.
/ Loader boom cylinders uneven #5
Is possible, although unless its completely closed off, they will equalize, just slower.
/ Loader boom cylinders uneven #6
I am referring to the structural tube that connects the two loader arms. If ever so slightly twisted or bent, it can show in the cylinders being at different lengths. It usually also presents with an uneven bucket while on flat ground.
/ Loader boom cylinders uneven #7
This is a very common issue and a very easy fix. I had it happen to me once when a stick hit my QA lever and unlocked it and allowed one side of my grapple to fall off causing it to be misaligned.
There are two ways to easily do it, either with a block inside of the hinge point, or placing one of the arms against a tree. Check out this video.
/ Loader boom cylinders uneven #8
I assumed he was talking about boom or loader arm cyclinders and not bucket cylinders or curl cylinders. sounds like the loader frame is twisted or like what was mentioned before somehow the mounting brackets are twisted or loose.
/ Loader boom cylinders uneven #9
If it's the actual boom, then you're probably right in being a twisted loader.
Yes, it is the part that the manual labels to as the boom cylinder, meaning the cylinders closes to the operator.
I appreciate all the replies. This is not a quick attach type of loader; I am not certain what "mounting plates" refers to (my tractor terminology knowledge is poor, my apologies). What drew my attention first is that the part called, in the manual, the "loader side frames" were not aligned. One is tilted corresponding to the cylinder that is extended vs the other. (If I understand the term correctly, loader side frame is the part of the loader sticking toward the operator that you maneuver into the frame of the tractor itself, hope I'm using the right term)
I don't appreciate any other twist or bend in the tubes holding the sides of the tractor together, but I'll get out there with a straightedge on Saturday.
If I can remove the snowblower (weather depending), I'll try to remount the loader and see if I can get more information, and maybe try the procedure from that video.
I'll post back when I learn more.
Ken in North Granby CT
/ Loader boom cylinders uneven #13
The mount that the loader connect to the tractor (the part that stays on the tractor) what I was referring to.
Those mounts bolt to the frame of the tractor and have some adjustment to them, you are supposed to check the torque for the loader mounts (where it attaches to the tractor frame) periodically as they can loosen, I've had it happen and had to re-adjust the loader mounts to everything to align again.
Have you used the loader hard lately? Such as using one side of the bucket to try and pry or ram something? It takes a lot to tweak the loader arms or torque tube.
Some pictures of the loader and tractor side mounts might be helpful.
/ Loader boom cylinders uneven #14
My first engineering job out of university was in structures at JD Dubuque (yellow industrial stuff). One of my first assignments was to analyze the torque tube on a wheel loader (the boss made it sound like there was a problem... ha). So I wrote the work orders, had stress coat sprayed on the structure, ran the machine doing various load cycles (showed lots of stress (fractured stress coat) on the torque tube and welds), had strain gages laid in the hot areas, wired it for telemetry, and ran a full out stress test. The torque tube lit up like a Christmas tree!... very high stress. I was excited... "gonna solve this one!" Ha!
It was really just an exercise for me to learn the process of tractor design and testing structures. Boss zeroed in on the torque tube region because he knew it is one of the most active (high stress) parts of the structure. I'll never forget it either. The torque tube's only job is to maintain alignment between the loader booms. Any uneven loading on the bucket is carried by the torque tube. The boom cylinders are pressurized together in parallel.... only the loader structure keeps them lifting evenly. Hope this helps!
/ Loader boom cylinders uneven #15
thats a good point, there is only one hose leaving the valve that acts in the lifting direction. it gets split into two so that both cylinders can help lift the load but it is the loader frame that ensures they lift together. If you cut the tube only the lighter side of the loader would lift and the other side would stay on the ground, assuming the bucket was off and the quick attach frames were not connected
/ Loader boom cylinders uneven #16
100% wrong & useless information. Lift cylinders (and most curl cylinders) are teed together on the tops of the cylinders & the bottom, they self equalize every time they move. WTF does a gland nut have to do with anything? He never said the cylinders are leaking.
As others have noted, the loader or frame got tweaked at some point. Many or most buckets don't sit perfectly level after a while as things get tweaked over the years.
Thanks. I will check those mounts; right now though the loader is off the tractor, and the boom cylinders are uneven. I've not had any particular hard use on the loader, or very uneven loads so far as I can recall. Pictures coming up. I appreciate your time.
/ Loader boom cylinders uneven #18
The cylinders aren’t going to be even if it’s off the tractor. They don’t have any form of synchronization. Go shove on one of the brackets and see what happens.
/ Loader boom cylinders uneven #19
What he said.... and right now we don't have enough information to figure it out for sure.
But it's an interesting problem and not uncommon. Some photos and measurements will help.
If I had to guess, I'd agree to look first at adjusting the plates on the side of the tractor where the loader uprights are fixed to the tractor. Many tractors have a quick loader disconnet there, and both the disconnect mechanism and the bolts holding those upright mounting plates to the tractor can move or get out of adjustment. In fact, if you loosen the bolts holding those mounting plates, you will be surprised how much the mounts can move.
I'm just repeating the good suggestion made first by TMGT.
But don't loosen the bolts that hold the mounts to the tractor until you have tractor and loader on a smooth surface and a some time to futz with it. It may take a few times to get it right.
Everyone worries about an uneven load possibly bending loader parts like the boom arms, torsional support tube, or the bucket pivots. Those are hard to bend, but always a possibility. The easiest way to check for bent arms, tubes, and pivots is to disconnect the bucket and the bucket quick change assembly - the SSQA - if yours has one.
When the bucket parts are not involved, all the pivot bushings on one arm should line up with the pivot bushings on the other arm.
Best way I know to test for a bend is to take a properly piece of really straight pipe as long as the loader is wide, and see if it will slide through the bushings on one arm and line up with the same bushing on the other arm. It should...
BTW, the problem is probably NOT in the cylinders themselves, although you can always swap them from side to side if you just have to prove that to yourself.
Luck,
rScotty
/ Loader boom cylinders uneven #20
Actually.... they're not that hard to bend.
Running stress tests on backhoes years ago, I was AMAZED at the differences in the stress generated between a pro operator and an amateur (like me) doing the same load cycle. You THINK you're smooth and being easy on the equipment until you look at the stress curves. Ha!... FULL of spikes.
Given that the machines we own are fairly light duty, the loader frame is especially vulnerable, and few of us make a living using them... a loader is not that hard to tweak. Hopefully the OP just has a mounting issue. JMHO
New/Unused Landhonor Power Rake (A65583)
New/Unused...
10ft Fork Extensions (A64553)
10ft Fork...
2009 VOLVO VHD BOBTAIL VACUUM TRUCK (A63569)
2009 VOLVO VHD...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
PALLET OF 14.9-24 TIRES & WHEELS (A64278)
PALLET OF 14.9-24...
2025 BS43 44in. Hydraulic Boxbroom Sweeper Mini Skid Steer Attachment (A64553)
2025 BS43 44in...
