M7040 cranks, but won't start
/ M7040 cranks, but won't start #1
jayman30
Victoria, TX
1977 Ford 3600, 2009 Kubota M7040 HDC
Hi,
I was clearing some brush the other day on my m7040 and accidentally broke the water separator bowl. I replaced the bowl but no fuel is coming out of the lines to refill it. The engine cranks over fine and I've tried running the starter with the key and by jumping the solenoid but no fuel come out of the rubber lines to the separator.
Thanks for any help or advice.
James
/ M7040 cranks, but won't start #2
If it has an electric lift pump, perhaps the wiring was damaged at the same time? My only other thought would be the valve on the separator.
Thanks for the reply! Looks like it only has a mechanical pump. I'm thinking the entire system got pumped full of air when the bowl broke - SMH... Anyone know where the bleed screw is on the injector pump on one of these? Thanks!
/ M7040 cranks, but won't start #4
Section from the Ops Manual for fuel bleeding.
/ M7040 cranks, but won't start #6
Thank you for updating your thread which only a small % of forum members find the need to give the final outcome.
I'm happy you got your M7040 engine operating again.
IMHO my Kubota M7040 engine is one of the easiest to bleed the air from fuel system of all the different tractors I've owned over 35 yrs of custom baling.
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
2007 Maserati Quattroporte (A61569)
2007 Maserati...
4 Shelf Rolling Cart 6ft x 3ft (A61166)
4 Shelf Rolling...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
207282 (A52708)
207282 (A52708)
4 Shelf Rolling Cart 6ft x 3ft (A61165)
4 Shelf Rolling...
