3 pr Hitch Hydraulic Pack
/ 3 pr Hitch Hydraulic Pack #1
bsekf
Gold Member
WNY
Kubota 7030, Long Landtrac 4700, Mahindra 5155
After reading the FEL Mounted Brush Mower / Trimmer thread. Thread is old, does anybody make a PTO driven 3 point hydraulic pack so you can run skid steer FEL mounted implements? Fabricating one would be cost prohibitive. I built a FEL mounted York rake and it works great to clean up woods roads.
How does the PTO disconnect? Is the pump on the tractor all the time? I expected something similar but with a PTO Shaft.
/ 3 pr Hitch Hydraulic Pack #4
Usually the pump connects directly on the PTO shaft of the tractor, but it's easily installed/removed. I'm sure there are models that have the pump mounted on the power pack and just uses a regular PTO shaft.
/ 3 pr Hitch Hydraulic Pack #6
I have one made by Quick Attach. Works my front mount hydraulic snowblower
/ 3 pr Hitch Hydraulic Pack #7
I didn't read that old thread but I'd be concerned if the hydraulic pack had enough weight for traction with a load on the FEL. Or traction on a slope.
/ 3 pr Hitch Hydraulic Pack #8
Add some weight to it and make it double function. Hydraulic pack and counter weight.
