3 pr Hitch Hydraulic Pack
   / 3 pr Hitch Hydraulic Pack #1
bsekf
WNY
Kubota 7030, Long Landtrac 4700, Mahindra 5155
After reading the FEL Mounted Brush Mower / Trimmer thread. Thread is old, does anybody make a PTO driven 3 point hydraulic pack so you can run skid steer FEL mounted implements? Fabricating one would be cost prohibitive. I built a FEL mounted York rake and it works great to clean up woods roads.
How does the PTO disconnect? Is the pump on the tractor all the time? I expected something similar but with a PTO Shaft.
   / 3 pr Hitch Hydraulic Pack #4
Usually the pump connects directly on the PTO shaft of the tractor, but it's easily installed/removed. I'm sure there are models that have the pump mounted on the power pack and just uses a regular PTO shaft.
   / 3 pr Hitch Hydraulic Pack #6
I have one made by Quick Attach. Works my front mount hydraulic snowblower
   / 3 pr Hitch Hydraulic Pack #7
I didn't read that old thread but I'd be concerned if the hydraulic pack had enough weight for traction with a load on the FEL. Or traction on a slope.
   / 3 pr Hitch Hydraulic Pack #8
Add some weight to it and make it double function. Hydraulic pack and counter weight.
2021 CATERPILLAR 926M WHEEL LOADER (A52709)
2021 CATERPILLAR...
2336 (A58376)
2336 (A58376)
JRB 54" QUICK ATTACH HANG ON WHEEL LOADER FORKS (A52709)
JRB 54" QUICK...
2014 BMW 320i Sedan (A55758)
2014 BMW 320i...
404 (A52706)
404 (A52706)
1775 (A58375)
1775 (A58375)
