Ceiling Fans Blowing Up or Down In Room With Wood Stove?
/ Ceiling Fans Blowing Up or Down In Room With Wood Stove? #1
HawkinsHollow
SE TN
Branson 3015R
I honestly think the situation can be different for lots of scenarios. I am looking for what you do and why, also, I'd like to get your opinion on my scenario. Here is my situation. The room our wood stove is going to go in is 12x25 with a vaulted ceiling about 12' at the peak. The wood stove will be almost centered on that tall wall. To the left of the stove about 10 feet is our kitchen that is an open wall with a cabinet and counter in about 2/3rds of it. There is a ceiling fan on both sides of the room with the woodstove almost centered between them but a couple feet closer the left side. My goal is to get as much of that heat to rest of the house, past the kitchen as possible. So the heat will convect up above the stove, part of my thinking is if I put the fans on a low blow it will set up a nice convection current, creating some good mixing. My other thought is if I put them blowing up then that air would move along the ceiing, hit the wall and follow it down where it would hit the counter and bounce towards the kitchen. Does it matter? Am i just going to have to experiment when I get it in and see which works best?
/ Ceiling Fans Blowing Up or Down In Room With Wood Stove? #2
We usually blow down in the summer and up in the winter.
Yes, and I think that will be the general consensus. And I get not wanting to blow potentially cold air down on someone relaxing on the couch. But I feel like there are times where blowing down might be advantageous, maybe?
/ Ceiling Fans Blowing Up or Down In Room With Wood Stove? #4
Our living room is 26ft to the vaulted ceiling. We def get more air movement down, tstat upstairs in the open loft stays slightly cooler down then up. Just have to figure out if the air movement down is comfortable or not for you in the winter.
/ Ceiling Fans Blowing Up or Down In Room With Wood Stove? #5
Same here down in summer and up in winter. It was explained to me as air blowing down directly on you offers a cooling effect from moisture on your clothes and skin evaporating. In heating season, heat rises to the ceiling and fans blowing air up don't blow directly on you, instead gently push that warm air out from the ceiling and down the walls.
/ Ceiling Fans Blowing Up or Down In Room With Wood Stove? #6
I wouldn't want air blowing on me in the winter, it would feel like I'm sitting in a drafty area, even with warm air. If air isn't moving to where you want it, there are corner fans, small, about 6" that you mount in the corner of a doorway to push air.
In your set up, I feel the fans blowing down would cause air disturbance, convection up meeting convection down. The result may be worse warm air circulation.
/ Ceiling Fans Blowing Up or Down In Room With Wood Stove? #7
Down high to get the warmth spread all around (windy though)
Up on slow just to keep the peak from hogging all the warm air.
/ Ceiling Fans Blowing Up or Down In Room With Wood Stove? #8
We have the one directly above the stove pulling up, and the one at the far end of the room pushing down. Creates a nice circulation loop in a long room with 14 ft. ceilings.
They're kept running on the lowest setting pretty-much year-round.
/ Ceiling Fans Blowing Up or Down In Room With Wood Stove? #9
My home is open through the LR,DR, and K with the woodstove in the LR. The other half of the house is cooler which is fine for the BRs. On very cold days, I'll have a small fan blowing cool air down the hallway from the BRs at floor level. That helps the warm air at the ceiling to get to the other side of the house. I also have a cold air return right above the woodstove so the furnace blower will circulate the air.
/ Ceiling Fans Blowing Up or Down In Room With Wood Stove? #10
Our ceiling is 10 feet tall. We have run the ceiling fan up to move around the heat from the wood stove but don't anymore. Even the slowest fan setting would move the air which was not comfortable. We have a single story house and the heat moves from the warm side of the house, i.e., from the wood stove. to the cool side of the house via convection.
Interestingly, I was watching a YouTube video yesterday that was showing an centuries old townhouse in London. One of the things that caught my eye was they had built a thin, wood paneling over the opening for the stairs on of the floors. The panel had two doors, one for going up a level and the other was for going down stairs. I think they did this for noise but also to keep the warm air in the room(s) on that floor instead of going up the stairwell to the next floor.
/ Ceiling Fans Blowing Up or Down In Room With Wood Stove? #11
Our house was built in 4 phases starting 1734, and has a door on each and every one of our several staircases. I honestly don't know how I'd live in a house without this feature, as they isolate noise in addition to controlling heat flow.
More interesting than their existence, is the wear imposed on them by past inhabitants. There was apparently a very determined mouse, trying to get thru this door into the 1775 kitchen at some point, before the kitchen was relocated to a new addition ca.1896.
This 1775 kitchen is now my home office, and that door is what keeps me somewhat separated from the noise of kids and family during the work day. The older 1734 kitchen is directly below, and is now our tiny billiards room.
/ Ceiling Fans Blowing Up or Down In Room With Wood Stove? #12
I’m also up in the winter and down in the summer.
/ Ceiling Fans Blowing Up or Down In Room With Wood Stove? #13
Whatever you decide to do, just remember that after running the fan in one direction for 6 months, stop it and dust the blades off before you reverse directions, or you'll get dust bunnies galore falling off the now trailing edge of the blades. Ask how we know. 🤣
/ Ceiling Fans Blowing Up or Down In Room With Wood Stove? #14
Once the living room is comfortable I have the ceiling fan on gently moving air up and the thermostat set to "fan on" which runs the air handler at slow speed to circulate the heat throughout my small 2-story house. Note the return above the stove.
/ Ceiling Fans Blowing Up or Down In Room With Wood Stove? #15
Reminds me of a Norwegian firewood debate on bark up or bark down on splits for optimal drying...
/ Ceiling Fans Blowing Up or Down In Room With Wood Stove? #16
We blow down year round. Mostly due to being too lazy to get a ladder and flip the switch, haha.
But in my mind it makes sense, I want to blow warm(er) air down and soak it into the floor and furniture. It doesn't feel great to have a wind chill when you sit on the couch, but honestly once my wife has our wood stove on full boil, I am in a t-shirt and enjoy the minor cool off.
/ Ceiling Fans Blowing Up or Down In Room With Wood Stove? #17
We use the ceiling fans blowing down in the winter to dry laundry on racks. It saves on energy and adds much needed moisture in the house. (y)
THAT IS SOME GOLD RIGHT THERE!! Now lets hope I remember!!
I wish we could of had a return above the stove. Our new addition has mini splits. But I will still try to run the fan over in the old half to see if it draws it over there.
I might have to buy the wife a couple drying racks.
/ Ceiling Fans Blowing Up or Down In Room With Wood Stove? #19
Almost never works as folks imagine it should. The trouble is that most houses have insulated ductwork running thru unconditioned space, with an air handler also in a cooler basement or attic, and it's sucking in air that's only maybe 80 - 85F from the ceiling above the stove.
The losses going thru the cold ductwork are enough that the air blowing out the other end is too cool. These systems were designed to be pulling hot air off of a furnace or heat pump at much higher temperatures, such that losing 10F or more in the ductwork and air handler isn't such a problem.
If you happen to design your own house and place all ductwork and air handler inside the insulated envelope, then of course it can work, and I know at least two people who did exactly this. But in any house you didn't design specifically for this purpose, it's usually a losing battle.
/ Ceiling Fans Blowing Up or Down In Room With Wood Stove? #20
Do not forget to install a smoke detector near the fire , not directly above
CATERPILLAR CB24B DOUBLE DRUM ROLLER (A52707)
CATERPILLAR CB24B...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
2017 Cadillac Federal 70IN Limo w 27466 Miles, Premium Federal Coachwork, Luxury Transport (A63118)
2017 Cadillac...
2025 Ford Transit Cargo Van (A56858)
2025 Ford Transit...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
1992 Norris Long Basket Trailer (A60460)
1992 Norris Long...
