Front wheels are popping and also the right side locks up.
   / Front wheels are popping and also the right side locks up. #1
Irap
TYM/T454
2015 T454 TYM. The front wheels are popping and sometimes the right wheel will lock up. I had the right side off and changed lower gear. It was chipped up but couldn’t find any bad bearings or anything that would interfere with the gears.
   / Front wheels are popping and also the right side locks up. #2
I have the same tractor. I have had to repair both sides. Snap ring comes loose or breaks. Then the wheel can come off if you don't catch it in time. The new snap rings don't have ears on them and fit tighter. Had to cut the grove deeper with a cut off wheel. I have also heard of some with bad ring and pinion gears, but I never had that problem. Not yet anyway.
Thanks for the info. I had the bad gears a couple months after I got it. They had to replace all of them.
2022 John Deere 5055E (A60462)
2022 John Deere...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2019 TerraGator 7300 Spinner truck (A56438)
2019 TerraGator...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
2016 DRAGON SAND CONVEYOR (A58216)
2016 DRAGON SAND...
2022 Brush Wolf 7800-HF Skid Steer Brush Cutter (A56438)
2022 Brush Wolf...
