Front wheels are popping and also the right side locks up.
   / Front wheels are popping and also the right side locks up. #1
Irap
TYM/T454
2015 T454 TYM. The front wheels are popping and sometimes the right wheel will lock up. I had the right side off and changed lower gear. It was chipped up but couldn’t find any bad bearings or anything that would interfere with the gears.
   / Front wheels are popping and also the right side locks up. #2
I have the same tractor. I have had to repair both sides. Snap ring comes loose or breaks. Then the wheel can come off if you don't catch it in time. The new snap rings don't have ears on them and fit tighter. Had to cut the grove deeper with a cut off wheel. I have also heard of some with bad ring and pinion gears, but I never had that problem. Not yet anyway.
Thanks for the info. I had the bad gears a couple months after I got it. They had to replace all of them.
2012 DIAMOND T TRAILER TRAILER (A58214)
2012 DIAMOND T...
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A55315)
UNVERFERTH 330 -...
1998 Ravens 39' Dump Trailer (A59814)
1998 Ravens 39'...
2002 International 9200i Truck (A56438)
2002 International...
2019 CUSHMAN HAULER PRO ELECTRIC GOLF CART (A58375)
2019 CUSHMAN...
2019 CATERPILLAR  XQ35 GENERATOR (A58214)
2019 CATERPILLAR...
