dfkrug
Super Member
- Joined
- Feb 3, 2004
- Messages
- 7,707
- Location
- Santa Cruz Mtns, CA
- Tractor
- 05 Kioti CK30HST w/ Prairie Dog backhoe, XN08 mini-X
I will bet top speed, on the level or downhill is maybe 35MPH in 6th gear.
I think these 3-cyl Mitsubishi engines are also found in Kei trucks, so parts should be available.My TN buddy just talked to a gentleman who rebuilds the 3 cylinder Mitsubishi engines on a regular basis.
I should have pulled the rear tires and wheels off of the red cab Toro before I sent it to TN. Once it arrived, there was no way the new owner would let them go. They were in great shape. I need to find another set and swap them out long enough to see just how much difference it does make. I guess I could take a set off one of the others I have, but those tires aren't nearly as nice as I would like to put on a Toro that I drive regularly.I will bet top speed, on the level or downhill is maybe 35MPH in 6th gear.
Plus I would need rims also!Yeah the rears are over 200 clams each. 12" wide and very high load capacity.
My GPS says it is only going 23 mph but it has solid chevron tires on it that never need air. Apparently solid tires were an option, and this one was used in an industrial setting. They are quite a bit shorter in rolling circumference than the standard tires. I like them because they don't go flat, but they do dig when off the road.I will bet top speed, on the level or downhill is maybe 35MPH in 6th gear.
Seems to be lots of Workmen in SoCal. I am giving all the innards of my spare 4x4 trannie to the buyer.BTW, last week I saw a 4x4 tranny unit listed on Craigslist in the Los Angles area for $900.
The year and model of your Workman would make a big difference to what you need.Does anyone have any parts, looking for a shift actuator, (that’s the piece on the auto transmission that the shift cable attaches to ) and a full glass door right side !
I see the new gas Workman UTV gets a bigger 1-liter engin
Does anyone have any parts for a 2015 Workman HDX Auto , looking for a shift actuator, (that’s the piece on the auto transmission that the shift cable attaches to ) and a full glass door right side !
I edited it thank you !The year and model of your Workman would make a big difference to what you need.
I purchased 4 and ended up only getting 3 doors to a Toro Workman cab. They are not the same as what is on my Toro Workman (Mauser Cab) but the hardware looks very similar, which probably means it is for a later model than what I have. I sold the cab unit I had that had a full glass passenger door on it.
My plan is to use the window out of one of the doors I bought to make a window in the passenger door. Currently my thoughts are to build another door and install the window to get a little more ventilation in the cab. Door isn't too hard to build, just 1x1 square tubing if I use the hardware from the later doors but right now I don't have time to do that. There just needs to be more ventilation in the cab. My cab has a heater, and if I don't pull the heat, I can just turn the heater fan on and it blows fresh air around the cab. That helps a lot.
David from jax
So no 14 HDX parts ?I have some Toro parts, tend to acquire them and then sell/trade them off to a buddy in TN. He and I bought 7 parts machines together because he needed a couple parts that were in a "lot" for sale. I made a seriously low offer and ended up having to go after them. Nothing anywhere close to being in this decade.
My buddy is the Toro Workman mechanic, not me. I just find a few deals and go after them.
David from jax
Probably not! I am not very familiar with the different models and what fits what. However, I will tell you that Toro doesn't like to reinvent the wheel, and uses a lot of parts that fit several different models.So no 14 HDX parts ?
